The agitator is no longer working on my washer. it fills up, sits there, and then eventually move on to the spin cycle (but this too is not spinning all of the water out from the wash). suggestions?
  • Washing Mach... Master
  • 932 Answers
What brand and model washer do you have? We need this info so that we can better help you. Thank you!
Posted on Apr 29, 2015
Testimonial: "amana washer c14522091"
Washer won't spin or agitate
what brand? model name and number would help. it might just need reset. or could be other problem.
Jan 26, 2014 | Washing Machines
My washer fills , sits, does not agitate, empties and spins.
I had the same problem. Take the agitator off by pulling on it extremely hard - use allen wrenches in the slots on the sides to help. This exposes the "air bell coupler" - take the 7/16" bolt out and slide it off. Chances are the spline is stripped out inside. The part is 5 bucks online
Feb 01, 2009 | GE WJRR4170E Top Load Washer
Washer won't advance from cycle to cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 16, 2008 | Danby DDW1805W Designer Series...
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills and spins but does not agitate
Im sorry to say, it sounds like the transmission in the washer may have gone out, the unit it self sits at the bottem of the main agitator shaft under the the tub, you may be able to have this replaced, but shop around for the right price.
Jan 26, 2008 | Washing Machines
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
