Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
F1 fault.intermittant.Wont drain. checked no leaks or blockages.pump good.it seems a valve isn't opening making a loud vacumn sound.
3 Suggested Answers
  • 8 Answers
SOURCE: DISHDRAWER IS SSHOWING FAULT CODE F1. WHAT ARE THE
F1 means the flood switch has been activated. here is a trouble shooting flow chart.
1. did a flood occure? yes. q-2 or no q-12
2. is the lid sealing on the tub correctly? yes Q-3 no=Answer
3. Is there a high water level in the tub. Yes-q4 no q-6
4. is the water valve leaking? yes=Answer no-Q 5
5. Is the dish drawer priming correctly? yes q-11 no q-6
6. Is the spray arm split. yes=answer, no q-7
7. is the spray arm running freely. yes q-8 no q=answer
8. is the water leaking from a split inlet or drain hose? yes = answer, no q9
9. is the water leaking around the heater plate or o rings. yes=answer, no q10
10. carroy out more testing to locate the source of the leak.
11. drain hose may have been blocked or partially blocked.
12. is there water or condensation around the chassis flood switch pcb.
13. if power fails to the bottom tub, it will cause the top tub to f1
Posted on Jan 31, 2010
  • 784 Answers
SOURCE: Water leak from top drawer. Had F1 flood alarm
Top right corner: it means the bad right actuator could not pull down the lid seal on that side causing a leak. The actuators are sold in pair. They are not expensive. Replace both of them when you order them in. Need to inspect the rubber seal around the top lid since if it is distorted another 60 bucks to get a new lid for replacement also. The new lid comes with the york to engage with the actuators.
Posted on May 08, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
Water will not drain out and makes buzzing sounds
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Mar 07, 2013 | Washing Machines
Machine wont drain
Jan 16, 2013 | Washing Machines
Smeg df612sdx dishwasher wont drain
Mar 12, 2012 | Smeg Dishwashers
Ariston a1436 water will not drain. when it gets to dump part of cycle nothing happens an machine makes loud humming noise. am i looking at a pump problem or an electrical one
Thank You for using fixya
Aug 17, 2011 | Washing Machines
Machine not spinning when the bottom right hand section is removed to check for blockage water pours out.
Jul 21, 2011 | Bosch Washing Machines
Hi my asko fron load washing machine model W621 wont drain properly anymore and makes a clunking sound as it tries to spin are u able to tell me what possibly could be wrong with it & if its worth...
Not to worry, please check from the drain hose from beneath and open the hose. Look for dirt inside for clogging into the valve/drain pump. Remove and clean the valve/pump if there is dirt. If not during the spin the valves must open and drain. if not check for the controller section for fault. The clunk noise could be misalignment of the suspension or the damper unit. tighen or replace. Hope you try . Good day
Aug 13, 2010 | Asko W6021 Front Load Washer
Same problem
Below is the service manual. Use the FU (fill water) function in the diagnostics and then use P2 to drain the water. Open the drawer and watch will testing.
Good Luck
http://www.scribd.com/doc/6462163/DD601V2-Manual
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer wont drain
check the pump for socks or anything that dont belong but put your hand on it while its in spin/drain and see if pump is even running
Dec 20, 2007 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
69 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
