Question about GPS
How do i unfroze my mediatek satnav
Switches on but screen frozen will switch off
What is the serial number
The serial number is on the box by the bar code. Also usually on a sticker on the back in tiny writing.
Dec 23, 2015 | Le Pan TC802A 8 GB Tablet - 8" - In-plane...
How do I unfroze the screen of my Cobra 6000 pro hd gps? Nothing works
Try to leave it on with no battery supply until it runs completely out of charge and switches off. Only then connect it to your PC and see if it communicates with the software on the PC. If it's still frozen you need to restore it to factory settings.
Dec 15, 2014 | Cobra 6000 Pro HD GPS Navigation Trucker...
Screen frozen
Mine kept doing that to, I had to totatly shut done and start over
Dec 25, 2013 | Ultratab JAZZ-C925 Tablet PC - MediaTek...
Mediatek inc
Mediatek.com could be your answer.
Dec 11, 2013 | Computers & Internet
How do i listen to radio while sat/nav is on screen
WHEN U ARE USING ANY MODE IE IPOD YOU HAVE TO PRESS THE NAVE BUTTON TO RUN THE SATNAV AS ANOTHER PROGRAM OR IT WILL SHUT DOWN THE IPOD MODE TO RUN THE SATNAV. AND USE THE NAVE BUTTON TO SWITCH BETWEEN THE 2 PROGRAMES.<!-- from fixya rte -->
May 24, 2010 | Car Audio & Video
Black DSi frozen.
Everyone i just found out how to fix a black or white dsi that is frozen and wont turn off!!
Step one:unplug dsi (if it is charging)
step two:close the dsi
step three:once it is closed turn volume down all the way witout opening
step four:set the dsi in front of a fan vent or someplace it will get a breeze
step five:open the dsi and hold power switch for like 6 to 10 seconds
(even when it turns off keep holding it for a couple more seconds)
now you an plug it back in and turn it on and VAWALä
hope this helped:)
Jan 02, 2009 | Nintendo DSi White Console
My LG Keybo is frozen on canceling message screen!
hey. it never unfreezes. i have the same problem. just take out the battery and the message will be sent if you go in your sent messages box.
Dec 31, 2008 | LG Cell Phones
Kitchenaid superba # KSCS25
Check the disconnect plug for power and good connection. Check the ambient temperature-colder the better but should be below 15 degrees. If the arm is down and all else OK replace the unit. Those IM's are throw away items now.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Frozen?
TRY TO CONNECT IT
Jun 11, 2007 | SanDisk Sansa e260 MP3 Player
GPS Logo
62 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
