Hone didplay says check tel line
Phone does not ring or work at all
  • 3,957 Answers
Plug another phone into the wall outlet and see if you get dial tone. If no dial tone, you will need to have the line repaired. If you do get dial tone, then there is a problem with your fax machine.
Posted on Apr 29, 2015
In normal condition phone continuously ringing what do
There could have been a short or ground in the telephone line (Tip and Ring). Please check the connection of the Tel line cord in the junction box. If your Tel line consist of 3 wires, disconnect all three wires, lift the handset, connect only 2 wires going to Exch Line or Trunk line (Local Tel Company) until you hear the dial tone. Leave the other wire disconnected.
This helped me isolate the problem, I hope this applies to you.
Best regards.
Sep 02, 2015 | Lands Phones
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
My phone says check tel line
Unplug your Phone and plug in a regular un-powered phone. If it rings your cordless base station is bad and you will need a new one if it does not ring then there is a problem on your phone line and you need to contact your phone company. Note, the phone company will charge you for repairs inside your house.
Dec 21, 2010 | Uniden Cordless Phone
"check tel line" message?
have you paid you bill? Seriously ring your provider and get them to check your line out.
Feb 12, 2010 | Lands Phones
Will not receive faxes. Line rings when phone was
make sure the mode switch is set to "fax"... not "tel", or "fax/tel". I think the mode indicator is on the top of the fax machine and it's a light that should be on next to "fax"
Oct 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Receiving and sending faxes
if the fax is connected to the same line and you have a phone connected to the fax you need to make sure you connect the line from the socket at wall to the correct socket on the fax you can check this by looking at the point the line is connected on fax there should be two connectors one says line and one says tel.. the line in goes to the line socket and your telephone goes into the tel socket.. if you have them the other way round it cant connect properly..on the front display panel make sure you have it set to the auto setting or tel fax mode for receive.. if you have it to auto it will check the incoming call if it is a fax it will send it through if not it will ring till you answer.. if set to tel/fax mode when it rings you will have to answer the phone and manually press start if you hear it is a fax.. Good luck A
Mar 04, 2009 | OKIFAX 4580 Plain Paper LED Fax
Answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Mar 28, 2008 | Uniden Cordless Phone
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
123 people viewed this question
jasbo
jasbo
