Question about Zenith Z37LZ5D 37 in. LCD TV
My Zenith TV Shuts off and will not turn on, no indicator light on, what can I do?
Shut off, now will not turn on, no indicator light on
    Top Expert:
  • Zenith Master
  • 75,581 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 30, 2015
Testimonial: "Thank you for that answer and site to look at."
DLP keeps shutting off
Check Lamp Fan or Fans and it could be that the Lamp is going out.
Oct 01, 2012 | Zenith Z52SZ80 TV
Zenith tv shuts off
There is a protection shut off, due to problems in the secondary switching power supplies and this might need attention of a qualified service technician
Jul 11, 2012 | Zenith Z37LC6D 37-inch Widescreen LCD HDTV
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Zenith 52'' dlp tv won't turn on
after an hour tv shuts off and you have to wait to turn it back on
Jun 12, 2009 | Zenith Televison & Video
TV turns off after about a minute flashing red light on lamp indi
your tv is talking to you basically, is telling you that the lamp has to be replaced. this is a common problem with this dlp tvs, when the lamp is bad the shuts off within minutes, so just replace the lamp my friend.
May 26, 2009 | Zenith D60WLCD Television
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Zenith DLP-Projection tv 42"
Try this solution which I found on Fixya
This solution is for the zenith 56" DLP. Unplug the tv, either from the wall socket or the TV. While the TV is unplugged hold the power button on the TV for 40 seconds. This lets the excessive power drain from the TV. If this does not work call 1-800-243-0000. This is the number for their help line. This is the fix the tech gave me and it worked right away. Hope this helps and have a great day.
Zenith dlp projection model z52sz80 turns off randomly
Further advice here. If the bulb is over a year old it is suspect.
LG DLP TV wont power up Red indicator lightjust blinks when
and where I got all this information frlom
zenith dlp projection tv blinking red light Google Search
Jan 09, 2018 | Zenith Televison & Video
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith Z37LZ5D 37 in. LCD TV Logo
223 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
