Question about HP Officejet 7500a E910 Multifunction Printer
Printing Problem in Hp officejet 7500a
My Hp officejet 7500a only print black,not even single color comes.I have new cartridges,I clean my print head with hot water.Setting in printer preferences is also good.I try to copy from printer but it only print the text or image which is in black color and miss that place where are other color...In printer utility it says that printhead health is good.What should i do any idea.Should i buy new print head??
jackboy
  • 2985 Answers
SOURCE: Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
Posted on May 11, 2007
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
technotech
  • 183 Answers
SOURCE: HP L7680 Printer Head Problem
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step two: Increase the print quality mode
If reprinting did not help, try increasing the print quality mode.
In the application you are printing from, click File, and then click Print. Make sure the printer is selected, and then click Properties.
Select the Paper/Quality tab. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:- This step does not apply to color printouts.
Make sure the printer is selected and click Properties.
Click the Color tab, and select Print Grayscale and High Quality.
Step four: Clean the printheads
If the print quality is still bad, clean the printheads.
Make sure the printer is loaded with unused white paper.
Open HP Solution Center.
Click Settings, Print Settings, and then select Printer Toolbox.
Click the Service Tab.
Click Clean Printhead, and then click Clean.
Step five: Align the printheads
If the print quality is still bad, align the printheads.
Open the printer Toolbox, and select the Printer Services tab.
Click Align Printheads. The Align Printheads window opens. Click Align.
The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed
If the print quality is still bad, calibrate the linefeed:
Open the printer Toolbox and select the Printer Services tab.
Click Calibrate Advanced Linefeed. The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads
If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
Press the Setup button.
Press 1 and * simultaneously.
Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
If the Black block has lines – replace the KY printhead.
If the Cyan block has lines – replace the MC Printhead.
If the Magenta block has lines – replace the MC Printhead.
If the Red block has lines – replace the KY printhead.
If the Green block has lines – replace the KY printhead.
Posted on Nov 10, 2008
  • 298 Answers
SOURCE: HP 3570 scanner not copying true colors.
Chuck the scanner (in my bin please) as the CMOS sensor is bad. Pick up a replacement at Goodwill for $10.00 and post for any help you need
Or sell it on Ebay for .99 + 20.00 postage.
Posted on Mar 27, 2009
Joed911
  • 4338 Answers
SOURCE: HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 03, 2009
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Will not print black. All ink if full, even replaced the black cartridge with new. Clean heads (via utility) 3 times. All other color cartridges (c,m,y) are printing. Work fine...
two actions I took that worked.
1) Remove the print cartridges. Raise the lever that holds the printer casing down (plastic square box), lift it up gently, remove it, and wipe with a clean, dry paper towel.
2) from the menu option on the printer. Go through the set up option and select "clean printer head" from the options. It will also do a self clean.
I did those two and it works nice.
Feb 08, 2011 | HP Officejet 6500 Wireless All-in-One...
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Jul 28, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printing blue
Printer defective.
need a new machine.
May 22, 2009 | HP Officejet 7210 All-In-One InkJet...
Standard black printing has faded to grey.
Could just be a faulty cartridge?
My hp printer developed a similar fault, and despite all my attempts to clean, realign, whatever, the problem wasn't solved till I fitted a new ink cartridge. It's worth a try.
Nov 15, 2008 | HP Officejet Pro L7680 All-In-One Printer
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Officejet d135 - "Supply Expired" error message
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
May 11, 2007 | HP OfficeJet t45 All-In-One InkJet Printer
HP Officejet 7500a E910 Multifunction Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
