Question about Toro Garden
Need motion drive belt diagram or manual for 2008 toro lawn tractor
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 376 Answers
SOURCE: Need a belt diagram
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=917.273638&pop=flush Enter your model # and search, scroll down to mower deck, and there ya are.It's an easy one. Straight across the back between the blade pulleys, then to the inside of both idler pulleys, then to the engine pulley. Hope this helps. Dwain
Posted on May 23, 2009
panilling9
  • 284 Answers
SOURCE: I have a OLD Craftsman lawn tractor 36'' Drive belt diagram ?
go to sears.com click on parts and enter your mod#
Posted on May 26, 2009
  • 32 Answers
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Posted on Jun 13, 2009
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
Craftsman schematic
Go online to Sears/Craftsman , or go to Youtube ,they will have videos explaining how to
Jul 17, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change the drive belt on a Toro LX466? Also, what would cause this lawn tractor to go thru one drive belt a year since 2008?
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
May 04, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
How do i replace a drive belt for the toro lx425 lawn tractor?
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Oct 10, 2010 | Toro Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
48 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
