Question about John Deere Garden
When I turn my john deere sabre off at the key the engine shuts down, however ten seconds later the fuse blows. Also brand new safety switches are killing engine when released. Suggestions?
Ignition switch, safety switches, battery, solenoid and magneto are all new. But diode on magneto is original wire and mower has all new wiring.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Somewhere, probably in the ignition switch circuit there is a short circuit - otherwise the fuse would not blow. You'll need to take a test meter to each circuit in turn to isolate the circuit and then find the short. Be logical and patient!
Posted on May 07, 2015
Testimonial: "Thank you! While searching my wires found that diode was bad after all! However safety switches although new and new wiring still do not work properly. And now engine becomes extremely loud after about an hour of running! Thinking of getting new motor! UGH!"
  • 640 Answers
SOURCE: engine shuts down when engaging mower on my L120
Most likely the seat safety switch is malfunctioning.
Posted on Aug 06, 2011
  • 640 Answers
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Posted on Aug 07, 2011
SOURCE: john sabre ride on mower
I have had similiar problem with the Sabre machine. On mine if the parking brake is set, and seat safety is closed and you pull down the blade engagement slightly further then the disengaged position the key will work. The only problem i continuously have even after replacing the battery is the low amperage cranking on ccold start...once warmed up starts no problem without the boost. I wonder if these machines typically have either a resistor built into the key switch which limits too much cranking power or if its something to do with the crank being sealed so tight as i also find it cranks over alot easier with the oil cap loosened up...just dont forget to tighten after starting!
Posted on May 30, 2012
  • 3698 Answers
SOURCE: why does a does a 14 hp briggs stratton rider mower engine keep blowing fuses
You still have a short or grounded wire.
Posted on Jun 04, 2014
pilipinas61547
  • 5 Answers
SOURCE: Why does my John Deere F735 Yanmar Diesel mower die when the key is released?
Your key switch is defective; replace it
Posted on Sep 22, 2014
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
I have a John Deere Sabre 1948 Hydro while mowing if I go in reverse the engine wants to cut off. What causes that?
It's a safety mechanism that will automatically shut down the PTO or blades. That's what you have going on. It's normal.
Oct 08, 2015 | John Deere Garden
John deere sabre 17 hs
sounds like the safety switches have been by-passed
not shutting off at switch may be the switch
Nov 19, 2013 | Garden
John Deere L110 what is the 20 amp fuse for?
Hi. That 20A fuse is basically the main fuse. But what is year model and is engine Kohler or Briggs & Stratton? It may depend on the above, but on an L110 the circuits that need to be protected are mainly the Charging Circuit, the Operator Presence Safety Circuits, and power for the Fuel Shut-off Solenoid which is under the carby fuel bowl. If the fuse blows the fuel shut-off solenoid will close and after a few seconds the engine will stop. But even if the engine could keep running the safety circuits would respond as designed and earth out the magneto and that would stop the engine. The engine has an AC "alternator" under the flywheel and a rectifier/regulator which changes the alternator's output current from AC to DC and then regulates it to suit the battery's needs. Depending on engine model this charging system may have up to 16A capability, so that is why the fuse is 20A.
Hope this helped
Pete
<ohpedro@hotmail.com>
Nov 03, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John deere lawn tractor 175. engine turns but No spark from spark plug
some of the safety switches will shut the spark off unplug the harness from the engine then crank it over if you have spark there is a problem with a saftey switch if you have no spark the problem is the coil
Apr 13, 2012 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
John deere 250 skid loader - purchased new in late 2001. every time i turn the switch to start the engine, it blows the fuse.
Apparently you have a short in the starting circuit. I would try disconnecting the start wire from the solenoid, and see if it still blows fuse. If it does it's in the control circuit. If not it's the starter solenoid.
There should be an operator present switch under the seat, that sometimes short out from an accumulation of dirt and debris that get moist.There is also a neutral safety switch and/or relays.
Oct 17, 2010 | John Deere 4020 Gas & Diesel Tractor...
Garden Logo
158 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
