Question about Craftsman 1/2 HP CHain Drive Garage Door Opener with Security Anti-Burglary Coding
We installed the opener and everything works as it should but every morning we find the door open. Then in the afternoon it usually closes itself.
I tried disconnecting the manual push button on the wall and took the batteries out of the one remote to narrow it down and still have the problem
    New Friend:
  • 130 Answers
Try erasing and reprogramming new codes..
Posted on May 03, 2015
  • 2,355 Answers
I would look for a shorted out wire to the wall button. maybe a staple thru the wires shorting it out. cold night and warm days expand/contract wires and staples and make a connection.
Posted on May 01, 2015
Testimonial: "We had already disconnected the bell wire ( at the motor )for the push button and it did not help. Thank You."
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
Alarm went off, now the central locking doesn't work
use the car key itself from outside the vehicle with everything closed: use key in drivers door outside door lock and manually lock and unlock the door. check if fixed, may have to do a few times. i do believe the vehicle is in theft mode.
Aug 18, 2012 | 1994 Volkswagen Golf
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
Craftsman 3/4 hp Chain opener.....Door opens and closes by itself. No blinking light, looks like everything is clear with sensors. Half opens then closes, then door completely closes and 5 seconds later...
You most likely have a bad wall control or the wiring to it. An easy way to check this is to remove the connection at terminal #1 on the rear of the motor unit. Just remember that your wall control will not work with this wire off. Your remotes will still work though.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener closes when closed
Try this: Loosen the chain enough that you can remove it from the sprocket above the motor. Now run the opener until the sprocket turns in the clockwise direction and stops. Reconnect the chain. This will get everything in sync and you will have to tweak the 'up and down limits' a bit to get it just right.
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage remotes and keypad don't work in the morning!
Something in the receiver portion of the logic board has become sensitive to cold. This is not uncommon in electronics. The sensors are working as they should and the wall control is hardwired and doesn't use the receiver. A new logic board is the repair. The lights are normally a simple repair. Unplug the unit and pull out on the center contact of the light sockets.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Antenna/distance
The receiver which is part of the logic board is going bad.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 - Will not close
What usually happens is a sensor gets bumped so that they no longer are pointed at one another. They must be for the light on the second sensor to come on. Tweak them and see if you can get the light to come on. If you can't you either have bad wiring going to that sensor or the sensor itself has quit working.
Jun 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP CHain Drive Garage Door Opener with Security Anti-Burglary Coding Logo
123 people viewed this question
Top Craftsman Building Materials Experts
richie46
ray gallant
robert
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
