Question about Digital Products International Clok Smooth iPod Docking Clock Radio TCR368
The digital display went off and then the radio stopped working. Where can I send it for repair or replacement?
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
2006 Honda Accord Vp Stereo System went out and i have checked every fuse and nothing is working! It started out with the DISPLAY ILLUMINATOR now the whole STEREO went completely Is there any
time to rip it out and fit a after market one ,it sounds like microprocessor has packed up and its cheaper to replace than mess around trying to get it repaired
Apr 27, 2012 | Cars & Trucks
Display has gone blank so cannot tune. can this be solved without going to a repair shop? technila dab 206 digital radio
You are experiencing a backlight failure. A repair shop can repair the item (grain of wheat lamp).
Once the backlight is repaired, you will see the characters on your screen.
Apr 12, 2011 | Audio Players & Recorders
How to replace 2002 radio light pont bonnieville and part number
Hello
I have repaired these burnt out display bulbs (3 of them) in GM Delco radio's, it is not a simple repair by any means, the radio must be removed from the car and then the radio chassis taken apart, the very tiny bulbs (size of a pencil point) are soldered to the front of the radio's main circuit board for the display, this job requires special pin point cordless low heat solder gun and a printed circuit board solder removal vacuum, The GM dealer does not service these bulbs, all they will do is remove the radio and send it out for repair to a GM radio repair center, if you do wish to attempt the replacement of the display bulbs they are a 12 volt 60ma, you will need 3 for the display, you can buy them from Radio Shack, the Radio Shack part # is #7219. You can also remove the Radio and send it in yourself for replacement of the display bulbs, this is what I recommend, if you damage the circuit board by applying to much heat the radio is so much junk.
Dec 12, 2010 | 2002 Pontiac Bonneville
My radio in my 2007 Acadia works fine , but the display just went blank .....Is there a separate fuse for the display ??? Thanks in Advance !!!
Unfotunately not. there is normally a small globe or LED running the face display. Remove the radio and open it up. Check the face side for any light bulb or LED. If it is a light bulb, you should be able to get a replacement part, Otherwise send it in for a repair. Hope this helps.
Jun 08, 2010 | Car Audio & Video
Clock/radio light went out. all other lights work
most common falt is light bulbs burn out in radio display and send in for repairs but is pricey
Nov 26, 2009 | 1997 Pontiac Bonneville
Car display console suddenly stop working
there is a module that controls that called the CCC- Car Communication Computer. My guess is that was damaged from the accident. hav a dealer check to be sure. Module is VERY expensive, so may wanna think about going through insurance for this
Jan 20, 2009 | 2004 BMW 5 Series
1995 impala ss instrument cluster went dead
Must replace the instrument cluster or send it out to be repaired.
Dr. Go
Dec 18, 2008 | 1995 Chevrolet Impala
2000 Nissan Pathfinder No radio Display
I heard from someone else that it is a circuit board. Cheaper to replace than repair.
Sep 30, 2008 | 2000 Nissan Pathfinder
Digital Products International Clok Smooth iPod Docking Clock Radio TCR368  Logo
187 people viewed this question
Top Digital Products Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Digital Products Audio Player and Recorder Expert? Answer questions, earn points and help others
