It can be you must remove oil filterand housing along with oil cooler lines lower trans lines you really need a repair manual for this kind of repair for torque specs and procedures
It's a question of access. Look underneath vehicle for any obstructions (Otherwise, obstructions must be removed first, e.g. support brace, splash shield, stabilizer, etc, ...). If you can see entire pan and all bolts, just drain oil and remove pan . Remove old gasket. Clean both surfaces. Install new gasket. Use high temp RTV (red). Replace oil pan. Hand tighten bolts. Then use correct torque and torque pattern.
SOURCE: change oil pan gasket
This Is A Fairly SIMPLE Procedure The IMPORTANT Thing is To Use Generous Amount of Sealant and Allow Plenty of TIME for Sealant to CURE After Pan is On and Tightened Over Night At Liest
REMOVAL
INSTALLATION
Happy Motoring and Have A Great Day . Also Please Dont Forget to RATE Me Thank You Very Much,rejakwilson
SOURCE: Is there ANY way to change the oil pan gasket on a S10...
Remove motor mount bolts and rear transmission crossmember bolts or nuts,suppport engine/trans. see if u have enough clearance between pan and axle remove pan. if not, split the exh away from the manifolds. worth a try
SOURCE: how much to change a oil pan gasket for 2001 grand prix 3.8 gt
If you want to repair the oil pan I would also check lower engine mount for leaking oil and cracks in anti sway bar near fitting's. This due to engine mount is oil filled. OEM sway bar is made of tubular steel and they crack easy. Replacement sway bar is solid steel. Here's the kicker. When they pull the lower frame to service oil pan. The engine mount and sway bar are attached to that frame. A honest mechanic should only charge for parts ($35 for mount and $100 for sway bar) and maybe a extra hour. My mechanic did all in 5 hours. FYI gasket is only $35 bucks. Good luck
SOURCE: 2000 silverado changed oil pan gasket rear main
Ouch. A main, rod, or cam bearing failure will cause these symptoms. Did this happen before or after this work was performed?
