Question about Sony 300-cd mega storage cd changer
Loads CD but does not spin to play - Sony 300-cd mega storage cd changer
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
Discs wont spin
If the unit turns on and loads to the PS2 menu attempt to play a ps1 game or cd. if these play the laser may be faulty. if these also do not play then the opical drive motor has malfunctioned. contact sony or a authorized repair center for further instructions.
Mar 05, 2011 | Sony PlayStation 2 Slimline Console
CR74-S ..THE CD PLAYER HAS NEVER WORKED..IT WILL NOT PLAY..IT LOADS THE CD AND THEN QUITS SPINNING
Unfortunately it is the laser pickup that is the problem, if it has not worked from day one it was flawed from manufacture, and if you happen to have warranty left I suggest you use it now, simply because to replace the assembly would not be cost effective.
Feb 19, 2011 | Crosley CR74 Turntable
My Dell Latititude E6400 Will not play CD's.
hmmm... well it sounds like you have a faulty cd drive. if your laptop is still covered by a warenty, then let the company fix it.
Feb 11, 2010 | Dell Latitude E6400 Laptop
Aiwa cd player model CXZR525U loads the cd's and spins but does not play
Try using a lens cleaner to clean the lens it is likely that the player cannot read the disc after it spins it.
Oct 07, 2009 | Aiwa HP-A091 Consumer Headphones
Cd loads wont play then ejects
HI, this is the result of a failed optical assembly. you can confirm by inserting a cleaning disk. if this continues after the cleaning attempt, have the optics replaced.
May 07, 2009 | JVC KW-XC550 CD / Cassette Player
CD won't play; continually shuffles from one CD to another
did it just start doing this....how long have you had the unit for?
Dec 16, 2007 | Kenwood CD-223M 200-Disc CD Changer
Sony 300-cd mega storage cd changer Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
