I HAVE A BUSH WASHING MACHINE ERROR CODE E01 WHICH SAYS THE DOOR IS OPEN WHEN ITS CLOSED.TRIES TO START CLICKS,WATER COMING IN THEN STOPS
ERROR CODE E01 MANUAL SAYS DOOR IS OPEN
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Probly door inter lock faulty
Posted on Apr 30, 2015
Water will not enter drum
not sure bout ur error code but would check the water inlet valve and the water pressure switch
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
E01 error
The control board is seeing the door as open even though it may be closed. Here is how to repair:
http://www.techanswerslive.com/appliances/bosch-nexxt-washer-error-code-er%3a01/1
Jul 24, 2014 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hotpoint aqualtis aqxxf149hpi is showing a error h20
Check tube to water pressure switch. The wall of the rubber tube on my machine had worn through due to friction. Taped it up to make sure this was the problem. No H2O code and machine working!
May 27, 2014 | Hotpoint Ultima WF860 Front Load Washer
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Bosch Nexxt Washer Error Code E01
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Dec 01, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag Maxima washer error codes E01 F08
Mine was resolved after changing the Symmons slide valve at the inlet to the hoses. This valve is spring loaded and does not work if not exercised as open and close on regular basis. My hot water supply was completely shut off and cold water remained open at all time. Check the incoming water pressure by unscrewing the hoses from washer and check water outlet by filling the bucket from both sources. Symmons slide valve at the wall is W-400 and was 25 years old.
Aug 16, 2012 | Maytag Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
The machine will not start. there is a clicking
E01 is a door open error,check all ribbon cables from the door wax motor to the control unit,then find the tech data sheet inside the machine and run the diagnostics on the machine,this paper is usually under the top cover
May 15, 2010 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
264 people viewed this question
Top Washing Machines Experts
