Question about Numatics Numatic Hetty 200a Hetty Hepa Canister Vacuum Cleaner with Autosafe
Static electric shocks - Numatics Numatic Hetty 200a Hetty Hepa Canister Vacuum Cleaner with Autosafe
  • 3,957 Answers
This occurs when the air is dry. The vacuum builds up a static charge when running. If you touch something metallic, you will get shocked. To dissipate the charge on your body, run your hand along a wall - it helps to reduce the shocks.
Posted on Apr 29, 2015
Why does my dirt devil max upright vacuum shock me? When im making laps, vacuuming.
if it is during vacuumming carpets it may be static electricity generated by the plastic head over the carpet
if it happening n hard surfaces , take it in for a safety check as there may be a loose wire touching metal and causing you the shock
Jul 30, 2017 | Dirt Devil Vacuums
Got a dyson dc14! Original. When hoovering i went to pick the wire up down by the bottom and got a shock. Is this just static? Is it normal? When using on carpets?
You stated you "went to pick the wire up down by the bottom and got a shock". If the wire was just a piece of wire that happened to be on your floor then you likely got a shock from static electricity. There should be no wires exposed on your vacuum so if the wire came from your vacuum that could be an electrical problem that could be very dangerous.
Mar 13, 2017 | Dyson Vacuums
Why does my bissell vacuum keep shocking me
Likely you have a short in the wiring somewhere. If you have a powerhead with a power cord that runs through the vacuum hose that might be the problelm. Check your cords closely. Is it possible you are just getting a static elecricity shock due to dry weather? If you think you are getting a shock, stop using the product until you have resolved the issue.
Dec 01, 2014 | Vacuums
Electric shock from handle
For safety reasons your electrical repair should only be done by a qualified technician.
Apr 18, 2014 | Vacuums
Hi, I've got an Henry Hoover. I've got electric
TRY RUBBER GLOVE / IT WILL STOP ELECTRIC SHOCKS ,I AM A CLEANER AND IT WORKS FOR ME
Apr 09, 2013 | Vacuums
Keep getting an electrical shock when using iron. is it possible to replace cables??????
It sounds like there is a bear wire inside the iron touching the case causing the shock. You have to take the iron apart and look for wires with cracked insulation and replace them or wrap electrical tape around the bear part.
Mar 16, 2011 | Vacuums
I received a NEW dyson ball vacuum for Christmas. I have noticed when I vacuum with it that dirt collects all over the ball and the vacuum beater head. Is this normal. I have had the regular upright...
This may sound silly, but it sounds like that you a have static electricity problem. If the dust is collecting on top (outside of the brush head that is probably the static attracting it. This is common during the colder months. You know how during these months when you walk across carpet and then just someone or a metal objest, you get a shock.
You might try lightly spraying a little "static guard" on the top of the brush head before using it, or using a carpet dusting product that smells good, and may reduce the static.
Jan 01, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Dirt Devil Upright Bagless
The cord may be bad, you may want to have it replaced, or have it checked before you get a bad shock.
Mar 12, 2008 | Dirt Devil M087500 Bagless Upright Vacuum
Numatics Numatic Hetty 200a Hetty Hepa Canister Vacuum Cleaner with Autosafe Logo
121 people viewed this question
Top Numatics Vacuums Experts
ray gallant
Are you a Numatics Vacuum Expert? Answer questions, earn points and help others
