Question about Janome Sewing Machines
Hi! I have a janome dsk30 that keeps beeping with the foot control light flashing. The only way to clear it seems to be to unplug the control foot and plug in again -any ideas?
  • 484 Answers
Sounds like it is getting too hot if it is OK after unplugging. Is something stuck in your foot pedal? Give it a clean and hoover as dust and threads can get stuck there. Good luck
Posted on Apr 30, 2015
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
SOURCE: Janome 5124 keeps running after I depress foot
Greetings, I experienced the same problem. Mine only ran a few stitches. Foot pressure on the foot feed was always "tension" problem in my foot.
I turned the foot feed around and upside down.
I press on the foot feed at the open end not the pivot (cord) end. This has given me much better control. Janome had no options for foot feed adjustment or replacement, but this has helped greatly. You may have to practice to get used to it
Posted on Jul 22, 2009
  • 1456 Answers
SOURCE: my machine will not sew. It beeps and the presser
Hello
First of all double-check your machine's power cord and make sure it's plugged in firmly on both ends--to the machine's power connection socket and to the wall electrical outlet.
Double-check that the machine is turned on.
Check the thread in the bobbin compartment. Make sure it is not tangled, and remove any tangled threads.
Check the bobbin winder. Make sure the spindle is not in the winding position.
Make sure the handwheel is in the sewing position.
If you have checked all these then the problem is from a sensor on the presser bar assembly that is
causing the machine to keep beeping There is a small flat metal spring that has gone bad and is causing the error.it thinks the presser foot is in the raised position so it keeps beeping
You need an authorized experienced dealer to fix this problem for you.
Good luck
Posted on Feb 06, 2011
SOURCE: are replacement foot controller for janome V/74088/649 still available
check with sewingpartsonline.com & sewvacdoctor.com
Posted on Feb 21, 2012
My Janome 6500 keeps stitching even when I'm not pressing on the foot pedal.
Next time it does it try remove the foot control cord to see if it stops. If it stops then it will probably be the foot control. If it still continues to run, probable the main board in the machine.
Dec 27, 2017 | Janome Sewing Machines
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Sep 13, 2017 | Janome Sewing Machines
I have a memory craft 9000 and it has just started sewing by itself..........HELP what can I do??
When it starts sewing by itself, unplug the foot control. If it stops sewing, then the problem is in the foot control.
May 03, 2011 | Janome Memory Craft 9000 Computerized...
My Rose sewing machine will not sew. It beeps and the presser foot icon flashes. I have re threaded, re bobbined, re placed the presser foot, and I think I have cleared the memory, but I am not really...
That light means you need to lower the presser foot. It cannot sew until the foot is lowered. The lever to lower the foot is behind the needle area on the back.
Feb 05, 2011 | Husqvarna Rose
Light is on but won't sew
Sounds like either the foot control or the motor has failed. The foot control is the easiest to replace, you should be buy a replacement control for about 30.00.
May 25, 2010 | Janome Harmony 9102D Mechanical Sewing...
Feb 27, 2009 | Janome D'cor Excel Pro 5124 Mechanical...
Janome 5000 screen remeins black
my needle keeps going up and down  after i stop a seam  is it my foot control? if i stomp  hard on foot control the needle stops as  it should
Jul 05, 2008 | Janome Sewing Machines
Sewing Machines Logo
231 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
