Question about Woodford Outdoor Faucet Repair Parts - Model 12 Faucet Repair Parts
Handle just keeps turning, how can i fix? - Woodford Outdoor Faucet Repair Parts - Model 12 Faucet Repair Parts
I installed a new 17 series single handle with temperature control unit several monthsa ago during a complete shower rebuild. No that I am ready to fire up the water, I can't get the water from from...
Remove handle and check temperature adjustment it maybe out. Remove handle and slide little adjustment gear out and move it a 1/4 turn and reinstall it to see if any difference occurs. If it is not set right you want be able to turn water off and possibly cartridge maybe be bad. With it being brand new and it should work out of the box take it back if no simple fixes will work. You want the best and not have to work on something you just bought anyway. Something may have been left off the cartridge maybe seat bad or o ring.
Aug 01, 2011 | Delta & Single Handle Shower Faucet
My mom broke the windshield wiper handle off trying to turn off my wipers because they wouldn't turn off and now I have to hold down the handle to keep my wipers on. What can I dod to fix this?
The windshield wiper/washer functions are incorporated into
a switch on the right side of the steering column. If the switch
is broken, you will need a repair manual to replace it or have
Honda take care of it.
Jan 29, 2011 | 1998 Honda Civic
Our 73 stay on as long as it is being primed so you have keep priming it to keep it on, then turns off 1 min after we stop priming it either reads ee2 or ee6
This site http://livesupport.maybenow.com/Rinnai/Rinnai-Toyostove-Direct-Vent-Heater-Laser-30-pr254029 handles prime issues directly for the unit. I would recommend contacting an individual in person that can assist you with the prime issues. This is a very sensitive issues which is best handled by having the problem fixed in person and not via email, chat, phone. (Lots of Danger factors)
Jan 26, 2011 | Rinnai Toyostove Direct Vent Heater:...
Bright light will not work. Pull back on handle and they work. Turn handle lose and they go out. This is 1998 chevrolet tracker.Push forward to turn on bright light will not work.
your dimmer switch is faulty. There's a catch inside the switch that keeps the switch actuated when you pull it back and release it, and that's not happening. You will have to replace the switch to get your brights working correctly. Good luck, and hope you get it fixed quickly.
Nov 21, 2009 | 1998 Chevrolet Tracker
Handle keeps wont stay up, keeps turning off.
Yes you can repair this. Sounds like the valve springs and the rubber valve seats may be worn. There are repair kits available at Lowe's, Home Depot, Wal-Mart, ect. for these faucets. And they usually come with the "tool" you need to remove the faucet handle and the cap and seal nut. After that, it's pretty straightforward, and easy. Two springs, two seats, and an O ring or two, and your'e done. Just make sure to shut off the supply lines to the sink before you start and open the faucet handle to remove any pressure left after you cut the water off. Tighten the cap or seal nut securely after the new springs and seats are in, and you should be good to go.
Sep 26, 2009 | Price Pfister Genesis Luxury Kitchen...
I have a shower faucet that keeps turning, does't stop.
Yes shut of main water, then remove handle, then take off bonnet, that holds stem in valve. You will have to take stem with you to hardware store to match up. Put it back together in reverse, turn main water back on. Now you tell everyone your a plumber and get much respect.
Aug 13, 2009 | Moen 2919 Chateau Two Handle Tub and...
One Handle Tap has gone random and hot/cold keep moving position.
look under the cap for a screw,see if you can tighten,if no screw under the handle is a plastic piece that is attached to the faucet diverter,this may have broken or the screw has come loose.you may have to replace the handle
Jul 30, 2009 | Plumbing
Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Feb 25, 2009 | Moen 2919 Chateau Two Handle Tub and...
Valley II lav. faucets new handles do not have ''stops''
Check with a local plumbing supply or decent hardware store (Ace) to see if they have handle inserts that will do the job. Don't know about Danco handles but I sourced some for another brand that worked well.
Good luck.
Jan 10, 2009 | Plumbing
Woodford Outdoor Faucet Repair Parts - Model 12 Faucet Repair Parts Logo
94 people viewed this question
Top Woodford Plumbing Experts
Paul Carew
Tom Chichester
Are you a Woodford Plumbing Expert? Answer questions, earn points and help others
