It fall in water what can i do to fix it - Audio Players & Recorders
  • Audio Player... Master
  • 5,631 Answers
Dry it, put in rice and don't turn it on until it's not completely dry. If won't work after that, consider it lost.
Posted on Apr 29, 2015
I have a 1993 mercury' marquis. The floor boads of the front part of the car get hot. And the thermostat keeps falling to c and rising to half way and falling on gage. Can u please help?! Thanks
possible no water in the engine and it is overheating
this is indicated by the temp gauge rising and falling
temp gauge sender units need to be immersed in water full time to get a reading so if it goes up that is in water and when it falls back that is in nothing or steam
hot engine would account for hot floor
Aug 14, 2016 | Cars & Trucks
I have water leaking out of left hand corner of water fall and steps going into hot tub i think it is leaking only when pump is on
Sounds like maybe the clamps have given way on your water fall return line and maybe your ozonator return. You will unfortunately have to take down the wall to get access. Check all of your unions and make sure they are tight, and then look for pools of water to show where the leaks are. If your completely insulated with spray foam look for saturation that will lead you to your leak. Once you fix the leak make sure to spray foam over your repair. How To Fix Leaking Hot Tub
May 20, 2015 | Pool & Spa
Samsung fall in water
it can be fixed on mobile shops
Apr 13, 2014 | Samsung Galaxy Cell Phones
The unit is several years old - the float keeps falling in and the unit shows full -can I get a new float and will that fix the problem?
If the float falling in tells you its full probably not. Unless the float floats off a switch. Then a new float that wont fall off would probably do it.
If the float keeps falling off...why not tie a small piece of fishing line to it and suspend it above the switch? It will stay where its needed until water lifts it up.
Jun 27, 2010 | Maytag M7DH45B2A Dehumidifier
The handle on my kitchen faucet falls down and
There should be an Allen screw on the underside of the handle. Loosen it to take the handle off, then tighten up the packing nut with a channel-lock wrench.
Sep 13, 2009 | Plumbing
How to fix a ninetendo ds if it falls into the water
i dont think you really can. better off buying the new dsi. and buy a water proof one too ;)
Jul 06, 2009 | Nintendo DS Lite Console
1994 GMC Safari Oil leaked out for no reason. Put more oil in...look under van and oil is leaking like a water fall. Turn Van off oil leak calms to a trickle. Other than the oil water fall the van runs...
Check the oil filter adaptor bracket. My 1993 Safari had the same problem, and the adaptor bracket and seal were bad. Replacement fixed the leak.
Dec 31, 2008 | 2002 GMC Safari
Nokia n70 fall in water
As soon as you got it out of the bucket/pool/drain, you should pull it apart and dry it using a hairdryer. If it's still not working take it to the stroe that you brought it from and they'll get it fixed.
Dec 13, 2008 | Nokia N70 Cellular Phone
46 people viewed this question
 Grubhead
Grubhead
