Question about KitchenAid Dishwashers
Dishwasher door is stuck - KitchenAid Dishwashers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
What make and model is your dishwasher,
Posted on Apr 29, 2015
  • 2 more comments
  • Crofter Apr 29, 2015
    I found this answer on another forum hope it helps.
    Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
    I found this answer on another forum hope it helps .
    Hi Dawn I found this on another site hope it helps. Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
    Read more: http://appliancejunk.com/forums/index.ph...
My GE dishwasher door is stuck closed
Have you tried wiggling it side to side? The diswasher may not be secured properly and will vibrate while running. If the counter opening is relatively small it can be hard to open the door if the dishwasher is off center.
Mar 15, 2015 | GE Dishwashers
How do I unlock my dishwasher door?
To avoid damaging the mechanism, you must remove the cover of the dishwasher and with a screwdriver blade can unlock the door from inside.
Jul 04, 2013 | Cars & Trucks
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Can't open door
Please find tips from the leink below on how to open and check the door locks and the latches.
http://www.espares.co.uk/advice/dishwashers/a/3
http://www.espares.co.uk/search/dishwashers/p/1083
Jan 06, 2012 | Dishwashers
My GE dishwasher's door is stuck shut ~ I'm assuming a broken latch. I was told to fix the latch, the dishwasher has to be taken out from under the counter top (in order to get the door open). My...
Well I'll try to help you get this opened. I don't know how much space you have at the top side edge of the dishwasher. You need a long stiff rod like a metal clothes hanger straightened so it can reach from the side to a little past the dishwasher middle. You need to push it in between the door top and the dishwasher body up at the latch area. What holds the door closed is a flat metal piece with a plastic hook on the end facing down towards the floor. You need to try and get the rod under the metal piece and lift it slightly, hopefully to unhook the the door. If you can't do that, the only alternative is to pull hard on the door handle and you should be able to break the plastic part of the latch which will then have to be replaced. The part that should break is the top hook which would be an easy replacement, but I can't be sure thats all the damage to the latch that will happen. It may do some damage to the part inside the door also. This is last resort. I'll try to attach a parts breakdown of the tub so you can see the latch hook. Look at item #50
Jun 10, 2011 | GE Profile PDW9880NSS Stainless Steel...
The dishwasher door is stuck closed.
oh no. get the crow bar and save ur crock pot!
Aug 23, 2009 | Dishwashers
Lock is stuck and the door won't close. The lights are flashing
Disconect fuse at breaker pannel. Then with a plastic dowel or blade trip the lock to oppen. Then it will operate normally. What happened is the lockig mechanisim shut down with the door oppen. Vitally
May 13, 2009 | Maytag MDB9600A Jetclean II Built-in...
GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher door latch
Its very east to open. Take the top cover plate off the appliance, undoing the screws at tha back and it will reveal the latch.
regards
george
Mar 30, 2008 | Dishwashers
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
