Question about Kitchen Appliances - Others
Where do i send my kettle back to ? model ti-gk-1114
    Master:
  • 456 Answers
Depending on where you got it ? some shops will stand by the 12 month warranty and either,swap it for a new one/give you your money back or give you a credit note to spend in there shop. some will give you the address to send it to. your first step will be to ring the shop you got it from. depending on age of the kettle they will give you the best advice. if it was a website then try and find a phone number not an email address ( look above the webpage for help and support/contact.)
Posted on Apr 29, 2015
Can we get a replacement kettle for this model
NOT SURE HOW OLD THAT IS . IT IS LIKELY STAR SELLS REPLACEMENT KETTLES FOR THAT BUT ONCE YOU SEE THE PRICE YOU WILL WANT TO HAVE THAT ONE REPAIRED. YOU CAN SEND IT TO ME AND I WILL LOOK AT IT FOR YOU.
Oct 16, 2015 | Star G12-Y 'Galaxy'' Popcorn Maker
Tip
Leakage problem at the bottom? Toastess International Kettle Model: TJK-103...
Leakage problem at the bottom…
Model: TJK-103 120V, 60 Hz, 1500 W
She was complaining that our kettle was leaking a bit at the bottom.
Warranty is over.
Here is what I did to fix the problem.
Unplug the kettle and empty it completely.
Remove excess residual water inside.
Remove the bottom cover by removing the screws holding it.
Gently remove the plastic ring screwed in place.
Now you will be able to put your hand inside the kettle and push the bottom out, toward the outside of the unit.
Take out the rubber seal and clean it. Ours was full of fine residue…
Gently dry it out and lube it with tiny bit of silicon.
Clean the inside part of the kettle before putting everything back together.
Make sure that you don’t squeeze any wires inside.
With a lot of patience, put everything back in place.
Make sure that the seal is perfectly installed. You can see it looking trough the plastic.
Kettle is now fixed and she is happy! ;-)
on Jan 23, 2008 | Toastess The Storm Electric Kettle
My rival electric teapot leaks, can I send it back for replacement?
Only the dealer and the manufacture can answer this question! I doubt you will find the answer on a public news group...
Jerry G.
Jun 18, 2012 | Rival 4071-WN Electric Kettle
I need operating manual for my Farberware 155B coffe urn
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For electric kettles try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FixYa!
Jul 09, 2011 | Faberware Farberware FSU236 12-36 Cup Urn...
How to make coffee
For electric kettles try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Sorry some one has not responded sooner but I think this had to do with lack of a ready source.
Feb 19, 2011 | Faberware Farberware FSU236 12-36 Cup Urn...
My TI Nspie CAS calculator is restarting frequently
If you remove battery door, the TINspire CAS cannot be turned ON.
You may try to reset the unit by pressing the reset button on the back of the unit. If that does not solve the problem, you may try to reinstall or update the OS.
Anyway, here is what the Texas Instruments Knowledge Base has to say about reinstalling the OS. Hope it helps.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Oct 08, 2009 | Texas Instruments TI-Nspire Graphic...
I have a TI-nspire CAS calculator. When it is switched on it begins loading and then comes up with System Error. What do I do?
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
Hope that helps.
May 08, 2009 | Texas Instruments TI-Nspire Graphic...
Russell Hobbs kettle element model 10413
The only way to get hard to find Russell Hobbs electric kettle parts is from Russsell Hobbs. They will not sell any parts that are in short supply or becoming obsolete. Please visit their website, follow the instructions for repair and send the unit to them.
Aug 19, 2008 | Kitchen Appliances - Others
Light switch on Breville SK500-XL Kettle
e mail askus@brevilleUSA.com
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
Jul 24, 2008 | Breville SK500-XL Stainless Steel Cordless...
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Kitchen Appliances - Others Logo
486 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
