Question about CDA CI592 Front Load All-in-One Washer / Dryer
Can you send me a picture of the front of the washer with the door open looking close to the brumbrum and the rubber sell
I think my rubber as gone the brumbrum and just need a picture to conform what it should look like
    Genius:
  • CDA Master
  • 1,585 Answers
The front part of the door seal has to come off to get at inter lock
Posted on Apr 30, 2015
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
Water was seeping thru the front opening while weasher was not in use. not an external leak. turned off both water suppiles and the water leak stopped. siounds to me like an internal valve leak
you need to change out the water valve on the washer.open the door and look for the model number.call your parts store and give them the full model number off of the washer,look around the opening on the frame where the door closes into and they will sell you the correct part
Feb 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Why does my ge front load washer leak from the door and will this be expensive to fix?
Hi from retired Englishman in SW France @21:10 Sat evening.
I think that we can only presume that the rubber sealing ring has been damaged, that is if the door is closing properly. If it is not closing properly the microswitch which senses if it is closed or not requires adjustment- which I think is less likely than the damaged rubber surround to the drum.
Sorry but I would not be able to guess what it would cost from where-ever (?) you live. It would have to be changed anyway unfortunately ;-0(
Best of luck,
John C
Jan 29, 2011 | GE WSXH208A Front Load Washer
How do I get rid of mildew smell in Siemens UltraSense front-load
Siemens
WFXD8400UC Front Load Washer
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Siemens WFXD8400UC Front Load Washer
Thinks the door is locked whenthe door is open and
pressure switch a new one or needs a clean not a hard job just be careful when looking that you unplug the washer first and try to blow into the little pipe that is on the switch
Dec 07, 2009 | GE WSXH208A Front Load Washer
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Bosch Washer
You know, Dealers would tell you any thing just to sound clever.
it needs a service,The reson being,on the back of the drum and under the drum you get bearings, i think 3 of them,they r filld with grease.Just take if for a service or if you can do it ur self,after that you can clean that door rubber with petrol, YES Petrol :).
Hope this helps you...
Sep 08, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machine smell
The problem comes from the design of the front load washers. There is always a little water left in the tub after the machine is used. Running a bleach load will deal with the mildew until the machine is used again. I leave the door open when I am not using my washer, and this does help.
Apr 10, 2008 | Washing Machines
Rubber Seal Holds Mold!
This is a problem that seems to show up on almost every front-loading washer due to the design of the rubber boot that attaches to the front of the machine. It is extremely important to wipe down the rubber after usage but even this doesn't always help. There are a couple of products out there that claim to get rid of the mold and smell, something called Purewasher that you could look up on www.smellywasher.com and also something that whirlpool sells for this purpose.
Mar 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
CDA CI592 Front Load All-in-One Washer / Dryer Logo
42 people viewed this question
Top CDA Washing Machines Experts
noel
noel
ray gallant
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
