Question about KitchenAid Kitchen Aid 42" Built In Dispenser Refrigerator Ksss42q
Plastic water line rattles when water faucet is shut off from any source in the house, including the wash machine. How can I stop this?
    Top Expert:
  • KitchenAid Master
  • 48,513 Answers
TAPE it down
Posted on Apr 29, 2015
Hot water stops flowing intermittently from tub faucet
Newer tub faucets have a anti-scald feature. It normally looks like a piece of plastic dial just above or below The tub handle. It could be that your water set too hott and he scald valve shuts off the hot water only
Sep 04, 2017 | Plumbing
Hi, I have the 1600 NG tankless water heater. Everything works great, but I installed low flow hot faucets throughout the house and now the igniter will not click on. It works for the washing machine. ...
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html#flow
1) Tankless require minimum flow rate before burner will activate.
2) Sounds like the water pressure drops quickly when faucet turns on. This implies combination of problems including sediment build up inside lines, crossover at single-handled faucet, or sediment filter clogged or water softener clogged.
3) Low flow faucets can reduce needed flow rate.
4) Other problems can contribute: sensor failure, loose wires, PC board failure, high temperature setting, cold incoming water temperature during winter months.
Jul 20, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Model LAT8504AAE Hot water pressure has been reducing over time, little by little. It is now only cold water. All house supply line valves are open.
screen in hot water fill hose is probably stopped up.turn water off unscrew hose at both ends check for a screen,if not in hose check at water inlet on washer pop out screen clean under kitchen spayer and reinstall make sure you put hose washers back in the hose ends that should fix your problem!!!
Jun 12, 2011 | Maytag Washing Machines
Model #ed22tqxvw00 problem: my water faucet in door was leaking when not being used so I turned off the water supply to the refridgerator but the faucet continues to leak drops of water. Where is the...
A couple things you need to check for your refrigerator water leak. First, if the water is actually leaking from the plastic tube for the water dispenser, and not from the flapping door that opens to allow ice to flow through door. If water is dripping from the flapping door, this could be ice melting, are you having any freezer temperature problems, is ice cream or bread soft ? If temperatures are fine, inspect the ice in the bucket, is it in clumps or one solid block of ice? If you have either this problem or the water is dripping from the plastic tube for the water dispenser, you likely have a problem with your water valve for either the ice maker or the water dispenser. Either way, both valves are part of one assembly, and both have to be replaced.
The other thing you need to check is that source water valve you shut off. Since there is no pump in a refrigerator, only those valves, the water that is leaking out of the fridge has to still be coming into the refrigerator. In other words, either that source valve is not shut off completely or it too is bad, or you shut the wrong source valve off, possibly for your house humidifier.
Nov 04, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Need help Have new house with 2 handle delta faucets, everything worked fine yesterday till I shut water off to install hot water heater now 2 different sinks have no flow hot or cold. Checked lines down...
Try opening all of your faucets in the house including the two that don't work. then go around the house and shut off one faucet at a time. Sometimes the air that gets trapped in a system will do weird things. I had a similar experience and finally the faucet started sputtering and then full water flow... still can't figure it out.
Mar 07, 2010 | Delta 3555RB-216RB Victorian Double-Handle...
I replaced a hot water faucet and the shut off... pulsation
I had this same weird problem. Turns out when I was under there I kinked the sprayer hose and made something loose on it. Straightened the hose and hand tightened all the parts to the sprayer and the pulsing stopped.
Oct 30, 2009 | Plumbing
Error 4E + timer countdown is delaying
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 02, 2009 | Samsung WF337AA Front Load Washer
Turn on cold water faucet and line starts to rattle
My experiance is something is clogging at the seat valve of cold side. Shut off cold water supply,remove stem,slowy turn valve back on to flush out possiable foreign object[s]
Mar 16, 2009 | Delta 2555SS-216SS Victorian Two Handle...
Samsung washer
Jan 28, 2009 | Samsung WF337AA Front Load Washer
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Aug 16, 2008 | Washing Machines
KitchenAid Kitchen Aid 42" Built In Dispenser Refrigerator Ksss42q Logo
62 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
