Question about Samsung HMX-F90 HD Camcorder Basic Kit White
I cannot get the menu to work, it comes on with Auto check marked, but cannot be moved either sideways or up and down
Scan for channels
press menu to bring up the onscreen menu, then us the up/down/ sideways buttons to move around the screen menu
May 23, 2018 | Televison & Video
How do you auto tune the Radio channels in or even do a search for different channels?
get the on screen menu up ( press menu on the remote) move around until you find auto tune , move sideways and it starts auto tuning
ti finds all radio and tv stations for you
when finished it may auto save or you will be required to press the ok button then exit
Mar 15, 2016 | Televison & Video
My dell wants to be sideways and it needs to be up and down
I just read Moon Reader disables auto rotation. You need to go into the program settings for moon reader. There may be a setting that allows auto rotation in the app.
Oct 04, 2015 | Dell Computers & Internet
Stalled the engine and now struggling to start and idle and making bad topend noise,as if valves are hitting pistons. Any suggestions?
If it starts then I would leave that possibility to last. I would remove the rocker cover and check the operation of the rockers as one may have slipped sideways and is not directly over a valve stem. t is also possible to check the valve timing with the rocker cover off. Turn the engine clockwise until the rockers on no 1 cylinder start to move watch these rockers and when you see no1 exhaust rocker start to come up then it will be getting close . Keep turning until you see the exhaust rocker stop moving up and the inlet no1 cylinder rocker start to go down. Move the crank back and forth until you get the position of movement either way moves either rocker. This is called valve overlap and if you look at the timing mark on the harmonic balancer pulley then the mark will be almost /on TDC
I would then run the fault codes as there may be other problems that caused the stall situation.
Aug 26, 2014 | 2006 Fiat Strada 1.6
How to change ip address on hp 5500ps
There are three ways of configuring IP address on any HP Printer:
A.- Using the control panel
B.- Using the web server
C.- Using the Jet Admin Utility
We'll deal with the contro panel setup.
To access the contro panel menus
1. Press OK (Check Mark) button once to access MENUS.
2. Press Up Arrow or Down Arrow buttons to navigate the listings.
3. Press OK (Check Mark) button to select the appropriate option.
4. Press Return to return to the previous level.
5. Press OK (Check Mark) button to exit the menus
So to configure IP address:
Press Check Mark
Navigate to the CONFIGURE DEVICE Menu using Down Arrow (the menu scrolls, so you may use any combination of Up/Down arrows)
Navigate to the I/O Menu
Navigate to the EIO 1 menu
Navigate to TCP/IP
Navigate to BootP entry
Press Check to disable it (Off)
Press return
Navigate to IP Address, press Check
Use Up/Down buttons to change the address, check to move between octets.
When finished, press Return
In the same way, enter Mask and Default Gateway
Press Return until you are out of the Menus.
Done
Jul 30, 2014 | HP DesignJet Office Equipment & Supplies
I have a vivitar vivicam t324, i cannot find where to set the date and time. please help.
hit the M key scroll over to were it says setup srcoll down its between digital zoom and auto power off it will say date
Nov 29, 2009 | Vivitar Cameras
Frigidaire crtr9300
from the top access ,
check the suspension out like you would a car,
move the drum up and down and sideways ,
it should resist and settle w/o bounce,
the springs should be tight.
the placement of the marks will give you an indication as to which opposite arm or spring is weak.
Jun 08, 2008 | Kenmore 46462 Front Load Washer
Toshiba laptop screen is east west instead of north south
If you click on the menu bar, you should be able to drag it down to the bottom. If you right click it is should also give you the option to lock it to keep it from moving again.
Dec 26, 2007 | Toshiba Satellite A105 Notebook
Convergence?
You have a fault on the convergence module. Might be an STK, might be something else but repair is definitely warranted.
Jun 07, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Samsung HMX-F90 HD Camcorder Basic Kit White Logo
628 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
