I have installed audio drivers but my head phones are not working when I connected in front panel. what should I do?
    President:
  • 778 Answers
Search for the latest updated driver for your Operating System from the PC's manufacturer's support site. You could post the Make Model of your PC and Head Phones here along with your Operating System and I'll gladly link you to the correct driver also?
Thanks,
Frank
Posted on May 16, 2015
4 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I have a Dell Dimension 4700 with M3918
That Xonar is an amazing card, as an aside are you able to do bitstream successfully to your receiver? Dolby HD and DTS HD successfully? If so I may just end up getting one of these cards :).
You should be able to do what you are looking for by just almost "breaking" that 10 pin straight line connector in half. I believe half of it is the AC97 and the other half is the HD connection, you can't really hurt anything by trying it one way or the other. Just try hooking 5 out of the 10 pins onto each row of jacks and test. You should also need to enable the FP headphone support in the Xonar software, it will look something like this screenshot here... as long as it is detecting the front panel jack correctly:
I hope that picture shows up large enough....
Posted on Sep 19, 2010
  • 961 Answers
SOURCE: I recently installed windows 7
http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
Try running this and see waht it recommends.
Posted on Mar 20, 2011
  • 1570 Answers
SOURCE: i will instal window xp
Hi
You install the sound driver of your computer and then update the service pack like SP 1 to SP3. If not try this to upgrade the service pack of your operating system or run the windows update.
Or download a nw sound driver compatible with your operating system. it might be out dated.
Run also, WINDOWS UPDATE.
Another way is go to the device manager, right on all sound devices install and then delete the sound device driver listed and restore your computer. You computer will load the best sound driver for your computer.
Or you install your sound driver unsuccessfully, Regards
Posted on Jun 24, 2011
Why would only 5 of 6 speakers work after new head unit car audio install?
Either that speaker is not connected or, the speaker is blown. To test: Disconnect that speaker from the stereo and, using a 9volt battery, tap the speaker's + and - to the battery's + and -. You should hear a "pop". That would indicate that the speaker works. DO NOT connect the 9 volt battery to the stereo side of the speaker wire!!!! 3_24_2016_7_22_43_pm.png
Mar 10, 2015 | Car Audio & Video
Sir, I am 58 yrs old having an interest in computers.I have Two Problems.I hope you will extent your help with your knowledge and expertize in solving the problems. 1. The front audio panel when fitted...
As per your information, there might be some problem with front panel microphone.
1(a). please check the internal cable for audio from motherboard to front panel. if possible change the internal cable.
1(b). If not avoid using the front panel and use the extention cables for extending from back points of speaker connection and microphone connection. just like usb extention cable you will find the audio/mike cable extentions can be found in local electronics shop. so that when ever you want you can connect speakers or headphone and also microphone.
2. For entering to BIOS, use either DEL key or F2 key when you power on the pc. In that you can see all the features. -
May be this helps to you.
Jun 17, 2011 | ASUS P7H55-M LX Motherboard
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
Mar 06, 2010 | Office Equipment & Supplies
My front audio is not working in my pc
If it works in rear audio port than for sure your front audio port from the chase it is not connected to the sound card, you have to open the chase and check this
Jul 18, 2009 | ASUS M2N-MX SE Motherboard
Not work audio front panel.What`s the problems. How to connect cables in motherboard. please help
The front audio panel will only work if connected to motherboard. Try
connecting to the audio panel in the back of the computer (directly
to the motherboard). If the rear panel audio plug (green) doesn't work
then the audio drivers that came with the motherboard might need to
be installed. Check your audio driver status with operating system.
Jul 08, 2009 | Abit GD8 Pro Motherboard
I am not getting sound.
1. Please check audio jack plug connection.
2. If connection has no problem, please check the Audio setting in Control Panel.
3. Please check the sound quality with an External / Head phone.
4. If problem persists, please re-install or update the audio driver. spacer.gif
You can download the most recent drivers from ASUS HERE
Feb 26, 2009 | ASUS M2N-MX Motherboard
Problem with front audio, i get sound with the back panell but not form the front the speakers and head phones work fine please see if you can help thanks
In some boards I've seen, the front connectors are not connected by default.You may need to review the manual.
Oct 09, 2007 | Intel Motherboard
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
