Question about SewShop.com Janome Sewing Manual 361 PDF
How do i thread trhis machine - SewShop.com Janome Sewing Manual 361 PDF
    Top Expert:
  • SewShop.com Master
  • 45,291 Answers
Read the instructions usually helps
Posted on Apr 29, 2015
Bobbin Not Winding Correctly
The machine seizes suggest thread wrapped around the shaft.
Jan 21, 2014 | Singer 7463 Confidence Sewing Machine 7463
Thread gets under needle while sewing. needle then cuts thread. is this a bobbin tension problem? thanks!
Hi. My guess would be no. Sounds more like an upper or needle thread tension problem than a lower or bobbin thread tension problem. Your trouble could also be the thread take-up lever was missed when threading the machine. Trace the thread path to make sure the threading is correct. Is this an embroidery machine? If not, were you trying make a darning stitch? Perhaps with the foot raised? Keep in mind that raising the foot loosens the upper thread tension.
Sep 09, 2011 | Vacuums
The Tesco EJ09 sewing machine upper thread is too tight on tension how do we alter this, we have adjusted as per manual
Is it the stitching that is too tight or the thread? Pull the top thread all the way out (un-thread the machine) and start over.
Aug 31, 2011 | Vacuums
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I do not have a manual and can thread for needles but the two other threads are a mysteryonce I get to the last bit the machine cuts but does not sew therefore I cannot be doing the threading properly...
First, you can search for a manual for your machine by searching with the make, model number, and the word manual. Like "Elna 6003 manual", and chances are you can at very least find a paper one to buy, but often now you can find free downloads in pdf format.
Then, most machines require that the needle be put in with the flat side to the back. If you're doing that, then check that you're threading from front to back. I can't remember about the one machine I used years ago that threaded from side to side, but it was probably the same, with the thread going from the rounded side of the needle to the flat side. But first, try searching for a manual. And are you using cheap thread? It's not worth the time it takes to thread the machine. Get at least Coats and Clark general purpose thread, if not something better.
Feb 28, 2011 | Vacuums
Only every 10 or so stitches holds. Probably a tension problem, but I don't have a manual and I've tried every setting and nothing seems to work.
A sewing machine should catch and tie the threads at any thread tension. If it's not tying and you're sure it's threaded correctly then it's out of time.
Timing a sewing machine is not difficult, but the point where you adjust the timing is often not obvious. I don't know what kind of machine you have so I can't tell you just where to set the timing, but you'll find the point in the lower section of the machine, there will generally be a screw or two that, being loosened, will allow the lower section of the machine (where the bobbin is) to turn while the upper section stays still.
You want to watch the needle and the tying mechanism: as the needle starts to come up the top thread becomes slack and the hook on the shuttle carrier (the piece that either turns back and forth or goes round and round, down below) catches the slack top thread and pulls it around the shuttle. If the hook is too early in its motion it can't catch the top thread, if it's late then the top thread is gone before the shuttle can catch it.
Timing the machine is simply a matter of determining if the hook is early in trying to catch the top thread or late. Turn the machine by the handwheel, watch the interaction of the needle and hook, adjust the timing if necessary and try it again.
If you don't see where to time the machine the next best thing is to take it to someone who knows, pay them, and watch where they're making the adjustment.
Good luck with it,
lp
Jan 19, 2011 | Vacuums
I have a Singer Imperial sewing machine, the bobbin winds in the machine, no manual with it. I have been trying to figure out how the bobbin is supposed to wind, I got it to do it one time trough trial and...
Does the bobbin have a metal "peak" on it? If so, drop it in the machine with the peak up. Slide the cover only about half way till the 2 arrows on the left match up. Thread the top as normal, put the machine in straight stitch. Thread the needle, then put thread under the foot and wrap thread around the post on the left. Leave foot up. Hold onto the end of the thread and start your machine. The bobbin should be winding now. After a few wraps you can let go of the thread and it should have broken off as you continue winding till the bobbin is full.
Jan 05, 2011 | Singer Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
SewShop.com Janome Sewing Manual 361 PDF Logo
49 people viewed this question
Top SewShop.com Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a SewShop.com Vacuum Expert? Answer questions, earn points and help others
