Could be quite a few, what is the model number. Do you have a volt ohms meter, if so check the cord first (UNPLUG) and across the switch then lock the switch on and check the brush holder leads. If you loose continuity anywhere in this process that is probably the problem. What did the brushes look like, did the mating surface look smooth or burnt. Let me know and I will try and help also give me the model number and brand, the header has 2 listed.
