Question about Frigidaire Washing Machines
My Frigidaire front load washing machine has stopped high-speed spinning. The regular spin works but not the high spin. Any ideas how to fix that?
  • tom cassidy
    tom cassidy Apr 29, 2015
    Hi Mike , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Official Brand Answer
  • 2,267 Answers
Hello Mike, thank you for your post!
From what you have described your Frigidaire washer is not spinning on a high speed. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician out to perform a proper diagnosis and repair on your washer. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Posted on May 05, 2015
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
SOURCE: Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
Posted on Sep 24, 2008
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 20 Answers
SOURCE: washer will not spin, will not spin in any spin cycle
Your water pump is clogged
Posted on Feb 10, 2009
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Posted on Dec 28, 2010
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I have a Frigidaire front load washer. Model #: LTF2940EE0 Serial #: XC64319573 and it is not spinning on high speeds. It is spinning but only slow. When I put it on the rinse/spin cycle it spins in low...
Motor has some shorted windings. Timer switches to higher current for faster rotation and the thermal overload protection shuts the process off as the current is too high because of the shorted windings.
Oct 04, 2017 | Frigidaire GLTF2940ES Front Load Washer
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
No spin cycle.
better chance that its the door latch assy, id change that befoer the timer
Jan 21, 2009 | Frigidaire FWTR445R
Frigidaire front load washer will not spin
Two possible reasons the lid switch may be defective, or the spin bearing may be worn.
Aug 31, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity Front Load
Mine wouldn't spin out the cloths very good,,they were real heavy and wet. I took the lines off of the pump and pulled it off,,,to my suprise,there was about $3 in change in the pump...cleaned it out and put it back together and it works great again. no idea what that had to do with the spin speed,,,,but it worked.....just an idea
Dec 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
