Question about KitchenAid Dishwashers
Kitchen aid dishwasher door stuck closed - KitchenAid Dishwashers
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
I found this answer on another forum hope it helps. Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Posted on Apr 29, 2015
  • Crofter Apr 29, 2015
    Read more: http://appliancejunk.com/forums/index.ph...
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
Kudi02cr Kitchen aid dishwasher not turning on. No lights nothing
check your breaker panel to see if the dishwasher breaker might be tripped. then be certain that the door is closing all the way and engaging the safety switch
Jul 04, 2014 | Dishwashers
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
Model KUDR01TJ wont work no lights on
1) test the fuse blown +c.breaker reset.
2) Test the switch door, if close not will close the startign relay, and will not operate the motor.see the diagram.
May 08, 2012 | KitchenAid Kitchen Aid Dishwasher Part...
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Dishwasher won't run. Normal light and cancel light flashing cont
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched.The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate. It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Thank you !!
Jun 18, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwashers Logo
76 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
