Question about KitchenAid Dishwashers
Dishwasher door stuck closed
Door stuck
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    New Friend:
  • 61 Answers
Hi Dawn I found this on another site hope it helps .Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Posted on Apr 29, 2015
I have a Kelvinator dishwasher,KD14ss, the door does not close ,ther is nothing in the way of the door ??
Hi Bets, It could be that the dishwasher door is hitting the installation cabinet or the screws holding it in place. Check to be sure the door is not hitting the cabinet or screws under the counter. Many times a screw may come loose and get in the way of the dishwasher door. If this happens the dishwasher door cannot close. Simply tighten the screw back into place and test to be sure the dishwasher door closes properly.
The dishwasher door hinges pivots on the bottom of the dishwasher frame. It holds the dishwasher door on and the pivoting allows the dishwasher door to open and close. If the dishwasher door hinges are bent or loose then the door cannot close properly. Replace the dishwasher door hinges if you find them to be bent or damaged.
Hope these will help.
David
Jan 27, 2018 | Kelvinator Dishwashers
The dishwasher switches on and drains the water out while the door is open coul you please help
There is usually and interlock switch for the door latch that shuts down the dishwasher if the door is opened. It sounds like the switch is stuck in the closed (thinks the door is closed) position. That switch may need replaced.
Jun 02, 2015 | Tecnik Dishwashers
My GE dishwasher door is stuck closed
Have you tried wiggling it side to side? The diswasher may not be secured properly and will vibrate while running. If the counter opening is relatively small it can be hard to open the door if the dishwasher is off center.
Mar 15, 2015 | GE Dishwashers
Bosch Logixx won't start - Stuck on "Close the door" even though door is closed.
Open the door, look along the top stainless on the door and you should find the ENr number (model number) etched into the stainless, may need to give it a wipe and look at an angle to read it. Post the ENr and that should help with diagnosis.
Mar 15, 2013 | Bosch 24 in. SGS69L02 Logixx Built-in...
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
Lights flash on dishwasher but it won't turn on
maybe a problem with the sensor 'door open/door close' check if its dirty or stuck if mechanical. press door to close and hold tight close while starting to identify.- or no sufficient water supply- or used water cannot drain out
Jun 15, 2012 | Frigidaire Dishwashers
The dishwasher door is stuck closed.
oh no. get the crow bar and save ur crock pot!
Aug 23, 2009 | Dishwashers
Lock is stuck and the door won't close. The lights are flashing
Disconect fuse at breaker pannel. Then with a plastic dowel or blade trip the lock to oppen. Then it will operate normally. What happened is the lockig mechanisim shut down with the door oppen. Vitally
May 13, 2009 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
66 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
