Question about LG Washing Machines
WF-T1022TP(H) INCOMMING WATER DOES NOT STOP
PHILIPDEBEER@GMAIL.COM
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
(1) Does water fill immediately after the power switch turns on before pushing the start/pause button? If so, there is a problem with a short circuit of the triac of the controller. Change the controller.
(2) Does water fill even though it is not energized (power is off)?
If the water fills, then you have a defect of the inlet valve, change inlet valve.
Posted on May 01, 2015
Testimonial: "Thanks for your answers. No all start normal but water does not stop on a level. Valve energized but does not stop the water after a few min."
  • Tedowen May 02, 2015
    Check the rubber hose that goes from the tub to the pressure switch, clean it out if necessary as this will also cause the inlet valve to remain on
    Genius:
  • LG Master
  • 1,585 Answers
Could b eather a pressour switch prob or inlet valve sticking open
Posted on Apr 29, 2015
My LG Fuzzy Logic WF-T1022TP let in more water than the level according to the weight of the bundle, sometimes even until the drum overflows. Is there something wrong with the computer?
Try shutting off power to the washer while the machine is filling with water. If the washer continues to fill with water even when it is not getting power, this indicates that the water inlet valve is defective. If the water inlet valve is defective, replace it.
Jul 18, 2017 | LG Washing Machines
LG WF-T6517TC my washing machine WF-T6517TC when it start to wash get Alarm "dE" beep and stop machine. what need to do
Don't know exactly what that code is but normally washing machines will beep and switch off quickly if the pump is blocked.as it's not allowing water yo be pumped around.
I suggest that is checked firstly before calling anybody out.
Jan 02, 2015 | Washing Machines
Please can you assist in providing a replacement part for my washing machine model # WF-T1022TP, the gearing needs to be replaced and Early bird seem to be unhelpful?
Try using buyspares.co.uk . It doesn't give you model but if you select a similar model like WFT1031TP it gives an exploded diagram to help find the part you're looking for
Feb 22, 2011 | LG WFT1071TP Top Load Washer
LG WF T6517TC Washing Machine does not fill water
sir
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
How does the gearbox on a LG WF-T1022TP work? Mine refuses to spin fast, and then it shows ''Spin error''.
hello i'd check the brushes first on the motor and spin control is down to the module circuit board good luck
shaun
Aug 31, 2009 | Washing Machines
LG WF-T1022TP Fuzzy Logic
hi my name is joyce
the pump is stuck. you need to get a pump replaced, a piece of dirt is all it takes to mess up the pump, exspecally if you are on well system, check the filter in the line and make sure its clean. if the machine is not spinning out, and its running the entire cycle the transmission is not engaging correctly, have this checked out.
let me know if you need further help
Thanks,
joyce
Feb 06, 2009 | LG WFT1071TP Top Load Washer
LG WF T1022TP Drain Problem
The problem has been traced to the water pump that does not turn on every occation that the power is applied. The pump just vibrates. Quess that it is worn out, and needs to be replaced.
Sep 12, 2008 | Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Water filing
Possible your outlet hose is at floor level; this must have a certain height, the height may be marked behind the machine. The hose should reach this height (approx 30 inches) from the floor level, and then go down into your wall outlet or whatever. The outlet pump pumps this water out over the height. Check this out.
May 22, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
50 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
