Question about Toshiba E-studio 855 Copier
Help scan file and e-filing toshiba 855
Photocopiers my toshiba e 855 scan button and the button E-filing is not working. My computer can not currently use it. one way to help me re-activate feature file scan button and the button E-filing
  • anhtruyen
    anhtruyen May 03, 2015
    Oh no. I mean the function button scan and e - filing on it inactive. it being someone lock lost not for the right to use its functions. you who know how to unlock the function buttons enable hoay scan and e - filing no. please help me
  • Toshiba Master
  • 643 Answers
Did u check via TopAccess ( MFP IP address ) whether the E-Filing is disable?
Posted on Aug 20, 2015
EmmettPinger
  • 63 Answers
SOURCE: When we select Scan to File and choose pdf file
Correct! Its a PDF but its just a picture of the characters you will have to OCR it to use the search feature. Good Luck  E-Copy is a good program for doing this or Laserfish
Posted on May 01, 2009
  • 2072 Answers
SOURCE: Scan feature greyed out on Toshiba eStudio 232
You have to have the USB stick to enable the scan.
It locates on the right side near the back of the machine.
They make , print dongles, Scan dongles and print scan dongles. But that USB device enables scan.
Posted on Jun 02, 2009
Copier_God
  • 57 Answers
SOURCE: cannot access shared folder where the toshiba
It sounds like you need to change the permissions of the share file, this would not be related to the copier as such as it just send the PDF/TIFF to the shared file.
Right click the file and check the permissions in the shares tab.
Posted on Oct 16, 2009
djuksoni
  • 103 Answers
SOURCE: How could i print pdf files with toshiba E-Studio 232
You need to buy GM1070 or GM1071,which are print enablers for es232.
Posted on Oct 29, 2009
tonesmaker
  • 60 Answers
SOURCE: toshiba 351c scan problem. when scanning we
go to the shared file on image
or try to make a search
Posted on May 23, 2011
Toshiba e studio 307 not print or scan becouse need to enebler sofwere
U need:
Print kit ( u can print or scan via e-filing/file downloader, cant use the SCAN button)
Print/scan kit ( Scan button let u scan to fileshare, scan to email etc...)
Apr 21, 2015 | Toshiba Office Equipment & Supplies
How do I fix currupt data
I believe you mean "corrupt data". When we have message corrupt data means that something wrongs with hard disk. You can try correct problem running full disk check.
Check your hard disk for errors
You can help solve some computer problems and improve the performance of your computer by verifying that your hard disk has no errors .
Open Computer by clicking the button " Start " and then click Computer.
Right-click the hard drive you want to check, and then click Properties.
Click the Tools tab , and then , under Error-checking , click Check . Administrator permission required If you are prompted for an administrator password or confirmation , type the password or provide confirmation .
To automatically fix problems with files and folders that the scan detects , select Automatically fix file system errors . Otherwise , the disk check will report problems but not solve .
To run a full disk check , select Scan for and attempt recovery of bad sectors . This scan attempts to find and repair physical errors on the same hard disk and may need more time to complete .
To check for errors in both files and for physical errors , select both check boxes AutoCorrect file system errors and Scan for and attempt recovery of bad sectors .
Click the Start button .
Depending on the size of your hard disk , this process may take several minutes . For best results, do not use your computer for other tasks while it lasts error checking .
note
If you select the Automatically fix file system errors for a disk that currently in use (for example , the partition that contains Windows), you will be prompted to reschedule the disk check for the next time you restart your computer your .
Jan 29, 2014 | Toshiba Computers & Internet
Toshiba Satellite A65-S126 keyboard no longer works
If you have the disk or driver for keyboard then reload it.
If not then use the mouse and click on the Start button, use the mouse's right button on Computer (My Computer). Select Manage. When the Computer Management console appears, Select Device Manager. Expand the Keyboard Section. Right Click on your computer name and select Scan for hardware changes.
If this fails to reload the driver then right click on the keyboard item that says Unknown and select Update Driver Software.
Jan 29, 2013 | Toshiba Satellite A65-S126 Notebook
Have Toshiba studio 450 & UbuntuX-Ser (computer name) with shared disk space via Samba. Have set Toshiba with save to file with \\UbuntuX-Ser\homes\john\store1\A_Scan as the folder to save scanned...
why not just use the public scan folder if you search network places for the machine IP there is a folder there called scans which is a public folder so everyone can use it.
Sep 01, 2011 | Toshiba E-STUDIO 450 Copier
File names and folders appear, however no files will open. nothing is being allowed to be copied or copy to it. Error 0x8007045D I/O device error
1) Download (0x8007045d) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Try that, it sounds like a registry error. If it doesn't help let me know.
May 04, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
I have scan utilities cd of toshiba e.studio 205/165, but could not succeed to install the scaner.
The scan utilities cd only contains driver.
If your scan button is working, u can select scan to twain.
Install file downloader, and u can download your scanned files.
Nov 04, 2010 | Toshiba e-Studio 205 Copier
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
Acer fp 855
Hi Dean,
Open your on screen display, used the +- buttons to go up & down. In this case used the - button to find the brightness setting. When you see reached the brightness setting press the first button ( the one you used to open the on screen) to activated the changed. Now used the + to adjusted the brightness to your desired. Well, hope i can help you on these. If not just give yourself a new LCD monitor for Xmas. Now a days...it's only cost about $200 for a 20" widescreen. Have a nice day!
Oct 03, 2008 | Acer Computers & Internet
How do we set up proper ftp server connection to receive scanned images with our Toshiba 232. the current file path is \\10.0.1.5/Scans\ but when we try to scan we get a FILE STORAGE ERROR. we have entered...
the path is all \'s not /'s. 10.0.1.5 needs a shared folder named scans and the copier needs a users valid login name / password for the computer sharing the scans\ directory.
Apr 01, 2008 | Toshiba Office Equipment & Supplies
Scanner
In order to use the scan features, (SCAN button on the panel), optional scan kit is needed. If your MFP is come with printer kit, u can scan using "store to E-filling". Install "File Downloader" software on your pc, and u can connect to the E-Filling of the MFP and download the scanned docs.
Nov 05, 2007 | Toshiba e-Studio 282 Printer
Toshiba E-studio 855 Copier Logo
57 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
