Question about Daewoo Refrigerators
I have a fresh multi-flow(old model) and it show "f3" and "NG".. any ideas? thanks
2 Suggested Answers
  • 340 Answers
SOURCE: Manual needed for Daewoo airconditioner
google email manufacture
Posted on Jun 20, 2009
I am facing problem from Kohler RS14, It is working/starting fine on LPG but not working on Natural Gas, on NG it is not taking starting, showing CC1, then CC2, then CC3 then stopped. And in case if it...
Is this set up for multi fuel????? or are you switching the fuel sources?
If the generator is multi fuel it will have two input gas lines one for LP and one for NG. If you are just putting gas to the one inley pipe IE single fuel it won't work. In naturalg as there is approx 1000btus of energy cu/ft in LPV there is 2513 almost twice as much. As such if a generator is not truly duel fuel, when it is set up for LP a small orfice to restrict the LPV gas flow is installed in the fuel mixer / carb. If you try and run on NG it won't get enough fuel, this orfice can be taken out and it should run fine.
Sep 05, 2013 | Kohler Electrical Supplies
My parents are getting an F3 on their Amana gas stove. This stove is about 9 years old. Not sure of the model. The burners are working fine, but they cannot use the oven. Any ideas? Many thanks!!
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Amana AEW3530DD Electric Single Oven
When tryingt to turn oven on it beeps and shows F3? andoven won't turn on .Not sure of model, But stove is at least * years old.
Hi
Thanks for using FixYa. Error F3 in your range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 26, 2010 | Frigidaire FGFB75D Gas Kitchen Range
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
My Noritz N-084M-NG residential/commercial indoor/outdoor Hot Water Heater does not heat the water when I get up in the morning. I have to go and switch it on and off again to get it to heat the...
That unit has two flow sensors. It needs to register flow through both sensors in order for it to fire. If one of the flow sensors is stuck or if there is scale blocking flow through the heat exchanger, it will not fire. I'd recommend contacting a servicer to clean the unit.
May 21, 2010 | Noritz 8.4 Gallon Residential Tankless...
Error codes
Hello raco1
Welcome
I need your model number to look up the fault code !!!!
You said , you see fault codes, FD F3 and E2 F3 is showing up on display pane
Looks like this may be your problem
F3 - E2 - Oven to hot -Replace oven temperature sensor
Waiting for your response.
When responding send me this whole communication . Not just your answer!
Thank you Huuum.
Oct 03, 2008 | Whirlpool RBD305PD Electric Double Oven
Kuya pno to ayaw lng tumugtog ng pc ko nauninstall kc ng kapatid ko ung driver ung para sa sounds
Dalawang possibleng paraan.
1. Sa Device Manager, right click mo yung na ka yellow mark na Multi Media/Audio Devices, pabayaan mong mag auto-install;
2. Sa COntrol Panel, click mo yung Add Hardware icon, Next ka lang ng Next.
Kung ayaw pa rin, post ka ulit dito lagay mo brand/model ng computer or kahit na motherboard model man lang. Kung may sariling Sound Card yung PC mo, paki post din Brand/Model. Turo namin sayo kung saan ka makaka download ng tamang drivers.
Maligayang Pasko.
Dec 24, 2007 | Computers & Internet
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Refrigerators Logo
57 people viewed this question
Top Daewoo Refrigerators Experts
jasbo
jasbo
Charles T Nevin
Charles T Nevin
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
