Question about Camping, Backpacking & Hiking
Can I run efel stove without water?
Can the thermal device be disabled on my efel oil stove?
5 Suggested Answers
SOURCE: i hahe a double pod efel oil stove, how do i
besem ab wold womenefs kudus ahadu amlak amien
Posted on Feb 20, 2010
SOURCE: having trouble lighting a second
plug in, open bottom and clean line end by twisting and pulling pushrod, make sure valves are on, tank must be higher do to gravity feed, crack open door 1/2 in, turn timer dial (one that clicks) all the way it should glow at bottom of crown, turn on fuel to low setting (just counter clock of the click), once flame is burning across the bottom of the pan close door all the way. The door open is so that it keeps stove clean for lighting also open the door for closing. If smoke is coming out of the door close it a little more. the stove needs to be clean and will stay clean for a long time if you open the doors. if it floods you need to clean it out. there are fuel adjust screws and air adjust counter weight but have a professional set those. good luck its a great stove once you get to know it.
Posted on Oct 25, 2010
  • 37 Answers
SOURCE: Have an efel oil stove, it lights ok but the crown
The gas orfeces are pluged up you need to take a wire brush and cleen them.
Posted on Jan 21, 2011
muntejaya
  • 10421 Answers
SOURCE: just looking for any info. on efel harmony 3 wood
Please get it here : www.fireplaces-oldham.co.uk/Euroheat_Harmony_Classic_Multi-Fuel_Stoves.htm
Multi-fuel > Nestor Martin">www.murphyheating.com > Multi-fuel > Nestor Martin
Kind regards, Jay
Posted on Feb 20, 2011
Buck stove 27000 fan runs on low but when goes to high will shut down moved temp gage to front and rewired with harness won't fun on manual either.
Buck Stove ' Hearth.com Forums Home
www.hearth.com/talk/threads/buck-stove.45094/
Jan 6, 2010 - I replaced the blower motor. immediately blower would run for... ... Buck Stove 26000 insert (1982, in the living room fireplace) Has kept ... I throught the same thing so I fired the stove really hot, motor would not run past low setting and ..... I have a pre-1979 Regular Buck 27000 where the thermal disks are ... Anyone burn an insert without the surround?
Jan 8, 2012
Insert Blowers - to use or not?
Jan 3, 2011
Buck Stove Fan Noise
Dec 27, 2010
Any HVAC Techs or Electric Motor Gurus Here?
Nov 22, 2010
More results from www.hearth.com
Nov 08, 2015 | Cars & Trucks
How should I store my cast iron skillet?
You should store it without the lid. If you leave the lid on then it is more likelt to rust. Some people even put a paper towel inside to protect against moisture. I leave a paper towel in all my pans.
Jan 16, 2013 | Home
Efel oil stove wont burn blue only yellow
Pull the crown and the two crown supports, scrape and vacuum the residual ash on the bottom and around the starter coil. Pull the and turn the oil feed tube scraper back out of the way. Reach inside the tube with a screwdriver and scrape out the residue until as clean as posssible. Exercise the fuel tube rod several times until there is no scraping sound. Vacuum the interior and replace the parts (Do not clean the crown).
Dec 23, 2012 | Cars & Trucks
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
Having trouble lighting a second hand efel oil stove what is the steps needed to take when igniting it
Sep 13, 2010 | Heating & Cooling
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
Camping, Backpacking & Hiking Logo
318 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
