If you have power at the outlet and the fuse is not blown, then most likely you have a blown component in the power supply for the unit. Without a schematic, it would be hard to isolate it to a single component. Take a good look for any damaged components or solder points, and then decide if you want to attempt to repair what you find.
The other choice is to take it to an electronics repair facility.
SOURCE: Unlock codes for Pioneer DVD player
Pioneer DV-667A
Converting the player to Multi-Region:
Requires the use of a Palm Pilot w/Palm OS 3.0 or later and the OmniRemote Pro from http://www.pacificneotek.com/
(Other PDAs using Palm OS and compatible with the OmniRemote Pro from http://www.pacificneotek.com/ can also be used).
1. Program the Palm Pilot/OmniRemote. For instructions on programming the Palm Pilot/OmniRemote click How to Program the Palm Pilot.
2. Power on the DVD player without any DVD in the tray.
3. Keep the programmed Palm Pilot close to the IR port of the DVD player.
4. Start the OmniRemote program.
5. Place OmniRemote in TV mode and tap the "0" button on the OmniRemote.
6. The DVD player will power off.
7. Power the DVD player on again. Check the Region-free status by playing a DVD.
SOURCE: how to use the usb port on Pioneer DV-410V DVD Player
Dear friends in problem solving.
My husband actually solved this problem by writing in the browser: Manual for Pioneer DV-410V DVD player.
That was available online and there it said that not all formats was supported by the USB port, so we tried to load a movie on a pen drive, insert it in the player and it opened and we just clicked play, so it was actually an issue of having an incompatible video file on the pen drive that made it not open in the first place.
Hugs from Solvejg
SOURCE: unlock region codes for teac dvd player, model dv-4180
Hi Pacificmarli
I found the following Multizone Instructions for Teac DV-4180:
Hope this helps.
Miche
SOURCE: I need to make PIONEER DVD player DV-310-K region free
I made it today,hurray!!!
Still need help??
SOURCE: looking for unlock codes to make pioneer dv-420v-k
Hi, Please get the code here :
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
www.220-electronics.com/dvd/ht.htm
www.videohelp.com/dvdhacks
Jay__Hbg654
BW-0392
6 in 1 Pre Programmed Remote Control DVD Pioneer codes:
0175 0185 0665
(source: http://www.antennawarehouse.com.au/remotemaster/tech%20support/Universal_Remote_Control_code_list.pdf)
To have a look at the universal code lists for other products, visit:
http://www.antennawarehouse.com.au/remotemaster/codes.php
(Skandia remote support site)
It is the closest I could get. Not sure if it will help at all. Give it a try.
Unfortunately you can't make it 'region free' but you can change the region as follows:
* power up the player without a disc init.
* press setup on the remote control,an osd will appear on the tv.
* select GENERAL using right cursor and use down cursor to select BASIC,press ENTER.
*press DISPLAY, the current region will be displayed.
*press CONDITION/MEMORY followed by 1,2,3,4,5,6 dependent upon the required region.
* press SETUP.
* your player is now ready for use.
If there anyone out there that could help me with the schematic for the PIONEER DV-383-S power supply board I would appreciate it greatly or email me on [email protected] thanx
