Question about Cell Phones
WEAR IS SLOT SD CARD - Cell Phones
  • 26 Answers
SOURCE: SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Posted on Jun 25, 2008
  • 207 Answers
SOURCE: sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Posted on Apr 21, 2009
  • 94 Answers
SOURCE: SD Slot doesn't work
If the SD card is a high capacity card (SDHC) the SD slot may not be capable of recognizing it. Suggest to try another SD card. If that still doesn't work find the drivers on your laptop manufacturers website.
Posted on May 11, 2009
Geekman
  • 32281 Answers
SOURCE: SD card does not seem to fit in the SD card slot
Is the SD card a mini type or a standard SD card?
The standard SD card is 24mm wide X 32mm long.
If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
Posted on Aug 14, 2009
SOURCE: sd card in cd slot of imac desktop
Use a large paper clip and fold it shaped. Gently insert it into the cd slot and drag the card out. My kid has done it twice so far. Make sure the power is off and if the clip hangs, don't pull.
Posted on Feb 19, 2010
Testimonial: "can't get a hold of anything, still trying thanks!"
Purchased soft wear upgrade for kenwood DNX8220BT from garmin when it arrived it is an SD card, how do I upload the information to my kenwood navigation system?
Press and hold the eject button for a few seconds. The screen will lower to reveal the SD slot. Put the card in and follow instructions when prompted.
You do not need to leave the card in.
Aug 20, 2013 | Kenwood KVT-512 Car DVD Player
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Can not gt my sd card into the slot do u need a spefic kind
Yes the type of card matters for the slot. If your pc/ laptop is newer and you have never used the slot, then more than likely the dummy plastic piece is still in it. This needs to be removed before you can insert any cards into it. Also, an SD card will only fit an SD slot, there are many other types of cards as well. If your card slot says that it will except SD, XD, miniSD, and so on.....then you can insert the SD card that you have.
Aug 27, 2011 | Computers & Internet
SD card
Hi friend,
Can you find the prompt text "TF(SD) card" and arrow keys when you open the back cover?If so,you just need to insert the SD card to have a try to see if it's the real slot.If not,you can try to find one slot that looks like the sim card slot,it may be the SD card slot.Try to find the place that has the chip.
If you have any questions about cell phones ,you can visit our website:www.1010store.com to get more helpful information.
Hava a good day!
Sep 23, 2009 | Apple iPhone 3G Black Smartphone
Aug 13, 2009 | HP Compaq nc6230 Notebook
May 11, 2009 | HP Compaq Presario V2000 Notebook
I like to up grade my sd card on my magelian 360 roadmate E-mail as follow:bojo9335@verizon.net
To change the sd-card do the following:
Peel back the rubber gasket to expose the SD card slot. Do not
completely remove the rubber gasket.
Push the SD card until you hear a click. Do not attempt to pull
the card out of the slot
Remove the SD card from the slot.
To Insert new SD Card
Insert the SD card into the slot (Do not force
the card into the slot.)
with the metal contacts going in
first and the beveled edge to the left.
Close the rubber gasket.
Mar 22, 2009 | Magellan GPS
How does the 5 in 1 card reader work on the Acer Aspire 5920 laptop? I am not sure how to get the SD card into this slot. Thanks
There should be 5 slots. Near each slot has the trademark of the card that the slot is for. If you are unable to identify the trademarks or there aren't any ways of finding which slot is which, then try each slot. Do not force your SD card into the slot. There should be only one slot that is the perfect fit for the SD card. Just slightly change the angle of the SD card until it slides in. The SD card has little to no extra room so it will take a little while to get the SD card in. Also the slot is spring loaded so you should here a click when it is in correctly.
If you have trouble, just keep trying and don't force it in. Trust me that it will fit if it is the right slot. Sometimes I get my SD card into my Wii or laptop in under a minute and sometime I have to mess with it for over 5 minutes (the angle of the stand for the Wii doesn't help at all).
Once you get the SD card in correctly, it will show up as a drive in "My Computer" but Windows XP and Vista have normal alerts with a "new hardware found" tone. Think of it as an USB flash drive that is smaller and goes into a specific slot.
When you are done, just push the SD card in and the slot should eject the card so you can pull it out.
Good luck and I hope you get it in.
Aug 15, 2008 | Acer Computers & Internet
SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Jan 18, 2008 | Toshiba Satellite M35X-S161 Notebook
-SD Card was renamed
From what I remember when this happens you empty the SD slot and do a soft reset. When the SD card is put back in it will be SD card. Similar steps when you put your SD slot device in.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
