Question about Toshiba E Studio 2330C
Periodic maintenance 01F1
The message is poping up all time and is annoying - how too fix that? And more - suddenly printer is freeezing, saying on screen "do not open cover, adding toner" - this message just poped in recently and while once gone, appeared again for some time and again gone .. what is that and why?
3 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: "Maintenance period reached" pops up on the screen
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
  • 66 Answers
SOURCE: "Time for periodic maintenance"
Go into (08) mode by holding 0 and 8 when turning on the copier. 251 is the number of copies until it displays that message and 252 is the count since last Preventative maintenance. Resetting 252 will clear the message or putting 251 higher than the value of 252 will clear it as well.
Posted on Aug 30, 2010
Toshiba 2330C periodic maintenance code 00FF?
machine ON .....0+8
code is ....252.... press start button
value input is......0
press Enter Button
time for periodic maintenance is clear.
Apr 01, 2014 | Toshiba E-studio 2330c 2830c Color...
My printer says unable 4F clean
4F message indicates that the print-head is gone, you will need to replace it to make it work again. Before you replace it, you may want to try this, see if it will remove the clean unable error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Jan 30, 2011 | Brother DCP-130C InkJet Printer
I have a brother MFC 440CN printer and it shows a message that says : unable to print 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Jan 09, 2011 | Brother MFC-440CN InkJet Printer
Apr 11, 2010 | Toshiba e-Studio 232 Black and White...
MFC-440CN screen says 'unable to print 4F'. How do I fix?
Hi there
Brother 4F
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 29, 2010 | Brother MultiFunction Center MFC-440CN...
My phones playing up its annoying..
It means that you do not have a valid sim card. Replace the simcard and see how it goes.
Mar 04, 2010 | Nokia E63 Cell Phone
Unable to Clean 4F
Hi there
With some Brother printers you can try this.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Nov 15, 2009 | Brother MFC-665CW All-In-One InkJet...
Jan 03, 2009 | Toshiba DP2570 Printer
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
Toshiba E Studio 2330C Logo
35 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
