Question about Brother Mfc-8220 Laser Multi-Function Center Fax, Copy, Print, Scan
It does not produce a dialing tone and it doesn't fax nor recieve
The all in one can only copy and scan but can not fax.
  • Brother Master
  • 3,957 Answers
Here are some things to check:
1. Is the unit attached to a direct line (not one that goes through a local PBX)? Many fax machines have problems with internal connections.
2. Is the phone line connected to the proper port? The port for the external phone normally will have a picture of a handset. The other port is used to connect to the phone outlet.
3. Try a new phone cable between the fax and the phone outlet.
Here is a link to the user manual if you do not have one:
https://content.etilize.com/User-Manual/10203508.pdf
Posted on Apr 29, 2015
I cant receive fax
Is there a dial tone if you pick up the reciever ? Can you send faxes or use the machine to make a phone call ? If you can make calls or send faxes the machine probably needs to be set to the auto recieve mode so that it automatically answers when a fax is being recieved. If no dial tone you may have a loose connection to your phone jack.
Oct 15, 2010 | Kodak 6150 AllInOne InkJet Printer
HP 5610 All-in-one can recieve faxes but not send, when sending a fax i always get the busy tone. connot understand why, recieves faxes prefectly.
Have you set for the proper dialing? there's a choice for pulse or tone dialing, you probably need tone dialing. Also the number needs to be put in just as you would dial on a phone.
Jul 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Fail to send and recieve
Well it was fixed after I called our telephonecompany.
They told us last Thursday that the lina was ok, but yesterday I talked to a extremely competent callcenteragent and he could confirm the problem lay in the connection.
So, it wasn't a problem wit the JX200 after all.
Jun 03, 2009 | Canon FAX JX200 - Fax / copier - ink-jet...
Brother mfc-260c not recieving fax, has dial tone.
Im not very familiar with that that model in particular. I would check to see if the is an auto recieve button on the control panel or in the fax settings. Just a thought not an absolute solution.
Jun 02, 2009 | Ricoh Aficio 450 Copier
No fax tone giving if this fax mode only
Using "on hook" you should hear a dial tone, if you have one then dial a known good fax number. It could also be in manual receive mode. -Carl
May 05, 2009 | Ricoh FAX1900L Plain Paper Laser
I am unable to send fax, I get a 'phone line error' message. The phone line is fine, I checked it by pluging a seperate phone into it. When I go to 'On Hook Dial' I do not get a dial tone on the fax...
Please check the dial tone by following the instructions given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up Arrow" or "Down Arrow" repeatedly until On Hook dial is highlighted.
4. Press "Select" twice.
You can now hear the dial tone of the telephone line.
5. Enter the number to which you want to send a fax.
Note: Press the keypad numbers to use an automated answering system.
6. Press "Start Black."
Mar 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Fax machine won't send or recieve faxes
press the "on hook" dial key. this should let you hear a dial tone. If you don't hear a dial tone, then it is probably the phone line and not the machine. You may have to call your telephone company.
Nov 26, 2008 | Ricoh Aficio 450 Copier
Sending a fax
First make sure that the fax button has been pushed and is llit...
The 2820 should have a handset. In order to use manual transmission (when you get to hear all the beeps and whistles) you will need to load the document then pick up the handset. then dial the number, when you hear the recieving fax tone then hit the start button.
The 2820 should also have a hook hold button pressing this will allow you to hear the dial tone and the numbers you dial along with the receiving fax tone. If you dont hear anything when you press this button then you may want to use the volume buttons to increase the volume.
Also remember that if you have not picked up the handset or pressed he hook/hold button the unit will use automatic mode, which is to say that all you will do is load the document, dial the number, and then press the start button.
May 19, 2008 | Brother IntelliFax-2820 Laser Fax
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Brother Mfc-8220 Laser Multi-Function Center Fax, Copy, Print, Scan Logo
152 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
