Question about Asko W6863 Washer
Is there a way to reset the control module on Asko front loader?
Control panel is on, no fault messages but is unresponsive to changing cycle patterns or starting a cycle
  • 351 Answers
SOURCE: asko w6761 front loader
you can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Posted on Mar 02, 2008
  • 5 Answers
SOURCE: ASKO w6011 FRONT LOADER
Try to Open the safety compartment using a screwdriver under the wash machine in the front.
Then open the big white knodb this will cause the wate to drain out which is fine.
Then clean this out. Usually you will find coins and stuff here from years of operations from pockets. clear these out and your problem maybe fixed. worked for us
Posted on Aug 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
Posted on Mar 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: asko w6441 housekeeper pushed buttons too
Hello John, Welcome to FixYa. I can provide you with an Asko service manual that should guide you on how to remove the panel and anything else you may like to do as well. The service guide I have is an Asko W600 series ( that includes yours ) from Asko in "pdf" so I could attach it to the email address you provide if you give the go ahead. I'll watch for your reply. Regards, Macmarkus :)
Posted on Jan 15, 2011
rickyrt441
  • 4399 Answers
SOURCE: Hi, my Asko W6011 Quattro
Thanks for choosing FixYa and welcome.
Posted on Jun 06, 2011
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
Error message: Thermistor Fault
yes it is serious as it indicates an over heating condition probably on the motor or control panel
May 17, 2015 | Asko W6761 Front Load Washer
My front loader works fine and will spin BUT it will not do the fast final spin cycle in the end to draw water out of the clothes. It shows that it has 11 min. left, does a slow spin right, a slow sp
Hey friend, thanks for your post!
I see that your Frigidaire washer will not spin on the final cycle. You could be having an issue with your motor or control panel. It is possible that the control panel is not sending the required information to your motor in order to process the spin cycle. Or it could be that the motor is not receiving the signal from your control panel to spin.
I would recommend performing a reset on your appliance which you can do by unplugging the power cord or flipping the circuit breaker for ten minutes. I hope this information is helpful. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
Having problems with fisher&paykel mw512au washer stopping mid wash
Fault code 240 is RPS
240.
(11110000) Hall Out Of Order. RPS Fault
Same as previous Hall Error faults See fault code130 for directions.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 20, 2012 | Fisher and Paykel Washing Machines
Hello, I have a 10 year old Fisher & Paykel smart drive 9 pride 5.5 clothes washer. Model MW059. When i start cycle, water starts filling and then suddenly stops for a second or two and then repea
That sounds like a bad RPS, you would get fault code 130.
faulty.
Action: Ensure the correct rotor for this phase of machine has been fitted.
Service manual, You will need Adobe reader installed to view PDF's
http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Feb 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Unresponsive control panel- Whirlpool duet dryer 4 years old
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&^^^
Nov 03, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
Mar 10, 2009 | Asko W640
Asko W6863 Washer Logo
50 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
