Question about Hisense Televison & Video
Hi there I need the replacement value for resistor R329 on the main logic board for hisense lcd32v77 please if anyone know
Slapnuts1975
  • 51 Answers
SOURCE: Sanyo main board
Sanyo 1-800-877-5036
Or... www.shopjimmy.com for used parts.
Posted on Aug 06, 2008
rulds2008
  • 3866 Answers
SOURCE: BOARS REPLACEMENT
Not the case at all its not a replacment for that model, wow I hate these OEM companies that think they have it right when there wroung.!!!
Posted on May 15, 2009
SOURCE: Power supply AD-12014(I) two smd burned
223 both
Posted on Mar 02, 2010
rylee_smith
  • 8619 Answers
SOURCE: model #50PC1DRA no picture but
Hi
Thanks for using FixYa. As you have already replaced the Z-sus and the main logic board then the issue seems to be with the Y-main and/or Y-sus board. You’ll need to take the back off and check for any blown/bulged capacitors that might have gone bad and causing this issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 02, 2010
welcomejee
  • 10594 Answers
SOURCE: hi i have a samsung 50",
These boards are not suppose to repair on component level nor schematics are available, in case of any part defective in board, complete board replacement is advised by Samsung.
So replace the board to fix your tv issue.
Thanks.
Posted on Oct 08, 2010
Jvc subwoofer will not power up
you can get the value from this link..
http://www.doctronics.co.uk/resistor.htm
Nov 01, 2008 | JBL LC-S960 Car Speaker
My Hisense F46V89C, 46inch LCD TV no longer turns on, and only Clicks. Can anyone tell me which component is the EEPROM i'm supposed to replace on the main board?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 29, 2015 | Hisense Televison & Video
Hisense lcd32v77 standby problem
Aug 26, 2015 | Hisense Televison & Video
Hisense LCD32V77
it must be a power supply malfunction; if you`re not a tehnician , please contact the nearest repair shop.
Nov 18, 2013 | Vizio L32 32 in. LCD HDTV
R47 resistor is blown on Neff S5453X0GB/07 control board. I can't make out the value as it is badly damaged - anyone know the correct value so that I can replace it (TY7 is blown as well!).
HI.We cannot really but identify the correct resistor value unless we can identify or determine the color coding on the resistor.Each color has a corresponding value and tolerance as well.If you can't indentify the color coding then you can refer to its diagram usually printed out on the side of the control board or near thecontrol board.We cannot but cannot give a guess value unless color coding is given.Thank you for choosing FIXYA.
Aug 27, 2011 | Dishwashers
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
I got this one dead. There is a burnt resistor on the main circuit board ( the one with the on/off sw). Would anyone know what value it could be.
You can determine the resistors value by reading the color code bands that are marked on it. The following picture is an example of the color codes and there values.
To show you how to read the color codes on a resistor, I am including a link to a video that will explain how to do this easier than I could probably explain it.
I hope this helps you in solving the problem. If you need further assistance please feel free to ask.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 15, 2010 | Fellowes 3011001 Shredder
Burned resistors r319,r320
ampmann,
hi mate, i might be able to help you but i need to know the exact model number and brand of your dvd player.kindly email it to workshop.fungkuei@vanuatu.com.vu
cheers,
markiez23
Jan 15, 2009 | Panasonic Televison & Video
Televison & Video Logo
46 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
