Question about GPS
Why wont my tom tom charge on my motor cycle
I used the 12 volt cord & plug provided in the kit
  • 813 Answers
I cant see aney reson why it shouldnt charge,try seeing if when you plug it strait on to the battery if it makes aney difference.
let me know,and all the best
Posted on Apr 29, 2015
Is there a kit or process that would to jump start a Boat that uses two 12 volt deep cycle Marine Batteries?
Sort of depends on how your two batteries are connected. If your boat is a 12 volt system, then any car type booster will do the trick, or you could simply add a 3rd battery with a switch. When you stop for a day's fishing, turn the 3rd battery off. Turn it back on for a quick "jump-start" and leave it on for the trip back to dock to keep it charged.
Jun 08, 2015 | Boating
Acer A500 wont charge
Is the supply/power cord functional? Does an LED light up when it is plugged in? If not, the power cord is the issue, make sure the cord is fully seated into the supply and the supply cord to computer is fully seated.
If the LED comes on, the problem is the battery is likely at end of life. They have a cycle of about 400 charge/discharge cycles, less if left plugged in all the time.
Jan 19, 2012 | Acer Computers & Internet
THow to get at reset button.Tom tom not charging when plugged into 12 volt in car.
There is a small reset pin 'hole' underneath nearby the USB/Power plug.
However, if your GPS is charging when you plug it to a PC or Laptop USB port, then I would suspect that the issue is more a faulty Car Power supply/charger (could be the cable or plug if you can see the pilot light on the charger).
ps. A cheaper alternative/easier to find to an original Tomtom car charger is a generic 5V (rated at least 1 Amp) USB charger used with your Tomtom USB Cable (that is what I use myself).
Hope it helps!
May 15, 2011 | GPS
I want to add 2 more 12v 20ah batteries to my 48w electric scooter and im not sure how to wire it and charge it.Please help
join them in parallel if there all 12 volt you could just charge the 1 battery with 12 volts and that would charge them all but all the other batterys have to be in series you cant do it if u have 2 24 volt batterys they all have to be 12 v
Dec 18, 2010 | Electric Bicycle Motor, Bike,electric...
I DO NOT HAVE THE POWER CHARGING CORDS... ONLY THEAIN PART OF THE LIGHT/INFLATOR . WHAT POWER SUPPLY CLORD IS USED?
On the side of the unit is a small black flap that covers two prongs that you can plug a standard 110-120 volt extension cord into which will charge the unit. There are 3 read lights and 1 green lights on the top that lets you know when it is fully charged. The 12 volt charging cord is basically a cord that has 2 cigarette lighter plugs. One plugs into the unit and the other plugs into a power port/cigarette lighter plug.
Jul 16, 2010 | Vector 1 Million Power Series Spotlight &...
My Tom Tom XL 325 wont hold a charge while left off
Hi, leaving the unit in the cradle exposed to the sun during hot days has been known to fry the battery causing loss of battery capacity. perhaps this could be your problem. I replaced the battery in my last GPS 4 times because of this before I analysed the problem. This will most likely be outlined in your user manual too. You might also compare the output capabilities between your blackberry and tomtom charger - it is entirely possible that you are starving the unit of a decent charge if the blackberry charger is not to the same current capacity as the tomtom charger.
Mar 19, 2010 | Tomtom One XL GPS Receiver
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Missing power cord 12v
go to radio shack get a 12 volt 1500ma power supply with I belive it is a N% plug end but any how 800 ma to 1500 ma should run this and the plug end is standard plug with plus 12 volts on the inner side and negitive on the outer case side look at the back of the TV or the old power supply it sould have info on voltags and amprage, and the plug as to inner voltage and outer voltage on the plug any old time radio shack or electronics shop should be able to help you bring in the flat screen if need be as if you know its 12 volts then It wont mater weather you use a 1000ma 1500ma 12 volt ubnaversale power pack as the tv will only use the current needed so more MA is good the only concrn you have is the right mini barrle plug and the right side of +/- voltage on that mini plug being most use + voltage in the inner most circle and - 12 volts on thje outer
Apr 05, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
GPS Logo
46 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
