Question about Exercise & Fitness
JUST STOPPED DO THE HAVE USES ITS A VIBELIE MAX PRO R209F
MADE A CRACKLING ON RADIO NEAR BY THEN TREADMILL LIGHTS WENT OUT AND WOULDNT TURN BACK ON MAYBE FUSE IF HAS ONE
  • 3,960 Answers
Check for a fuse holder near the power cord on the unit. If you do not see one, chances are that there is not one that is user changeable. If you heard crackling on the radio, chances are that it is not a fuse. Fuses open immediately to protect the equipment, so a long duration of noise would indicate a different electrical problem.
If you have your manual, please consult it about a fuse.
Posted on Apr 29, 2015
New starter wont start just click
Will it jump start? What shape is the battery in?
Mar 23, 2014 | Dodge Grand Caravan Cars & Trucks
Tablet not working
my tablet just went dead and wouldnt come back on i tried charging it
Jan 14, 2014 | Computers & Internet
No power in bike
Have you checked your fuses?
Jan 18, 2013 | Hyosung GT 250 Comet Motorcycles
My slendertone wont turn on. it did and i turned it off!! and when i went to turn it back on it wouldnt turn back on and i have changed the baterys!!!
I've had the exact same problem! I turned it on, and the lights went on then I looked at the next step in the manual and thirty seconds later max when I looked at the belt it had turned off! And now it won't turn on again! I've changed tha batteries and it still won't work! Please let me know if you find a solution!
Aug 13, 2011 | Slendertone Fortex
Tv turned itself off and will not turn back on
when pushing power switch the green light turns on with a crackling noise and goes back to sleep mode wont turn on
Feb 22, 2011 | Pioneer PRO-620HD 58" Rear Projection...
Lens is stuck out and wont go back in
dust or bigger item in lens! must get pro cleaned... either that or bumped into damage...
Dec 23, 2009 | Samsung S760 Digital Camera
Tail Light and License Plate lights stopped working
With light switch on, test the wires leading up to the mentioned lights with a test light(cost about 5 or 6 bucks at wal-mart) that way u can eliminate any corrosion questions and get to the source quicker, if test light indicates that the wire is hot, than check connection areas for any wear and tear and possible carbon corrosion. Check lightbulbs, my license plate light stopped working and wire was hot, but wouldnt turn on due to the housing base, got too dryrotted and wouldnt function propery, had to rig it up, but works now.
Jun 08, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Sony wega kdf-50we655 went off and thier is a buzzing noise
Anything that sounds like electrical crackling will be coming from either the lamp or lamp driver/ballast boards or their interconnections. The lamp should be examined first as this is the most likely cause.
michtech
Feb 11, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Exercise & Fitness Logo
43 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
