Question about Clothing Accessories
Has a mouse hole half inch by one and a half inch on the crown
Needs cleaning, blocking,and interior silk repair. Can you help?
2 Suggested Answers
  • 3 Answers
SOURCE: I have a old Haubold
Ample Supply Company stocks Haubold parts. You can contact Roy at royz@amplesupply.com, or call him at 800 982-7100.
Posted on Jul 14, 2011
What is the most realistic type of artificial flower?
The most realistic looking flowers are made from silk.
Jan 14, 2013 | Home
No front wheel drive
Most probably a problem with the differential. Best solution would be remove it from its case and repair it.
Nov 17, 2011 | Cars & Trucks
I put in a cleaning tape, and when it finnished it told me to eject it, so i did and it popped up, but only finnished half of the ejection precess. now it wont go back in or come out all the way and im...
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Oct 09, 2011 | Video Cameras
Will only run with the choke half on
The carb is blocked. Remove the barb take out the main jet blow out the holes and make sure they are 100% spotless rebulid clean out your filliter and that should sort your probleml davidson lawn mower tech
Feb 07, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Recentley purchased and installed Microwave spacemaker oven . Interior white enamel has a small perforation that is not covered. All the others are. Can this be repaired? Should this be repaired?
There are no repairs that I am aware of. The hole would have to be at least 1/4 inch to worry about microwave leakage. (see the size of the holes in the screen in the window, which safely blocks the microwaves from passing through the window?) My concern would be cleaning and possible rusting over time. If it is indeed new, I'd ask for a warranty service call, and see what they say. They may just be willing to exchange it for a different one.
Nov 04, 2009 | Dishwashers
Crown Vic Fuel Line
I do not recommend doing this.
a 1/4 inch line has a .0491 square inch hole.
a 5/16 inch line has a .0767 square inch hole.
This would result in lowering the flow capacity of the line by over 30%.
You can possibly starve the engine of fuel causing the engine to run lean, which can result in overheating and even worse melting the tops of your pistons in the engine.
Most good automotive stores have many types of brake line and fuel line fittings and adapters you can purchase.
Good luck with your project!
Sep 09, 2009 | 1992 Ford Crown Victoria
Taking out my radio for a new cd deck
look at the factory radio is there 2 holes on each side about an inch and a half above each other one set on the right one set on the left? if there is you need a special tool available at most auto parts stores for around $5
May 16, 2009 | 2000 Ford Crown Victoria
1989 Caddilac Brougham 5.0 L engine with carburetor. During water pump installation the bolt that connects the power steering pump to the engine block is not threading. The 1 and a half inch bolt would not...
Try loosening the other bolts if you haven't already, start with that on with either a longer bolt just to chase he threads or use an awl or tapered punch to line up the holes
Sep 16, 2017 | 1987 Chevrolet G20
Clothing Accessories Logo
494 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
