Solution to rectifying this error occur on bizhub c20. 4FFF
Write your answer...c503
Posted on Jun 22, 2015
  • 3,960 Answers
4FFF: Controller connect error - MFP board/1 (MFPB/1) to MFP board/2 (MFPB/2) connection failure
1 Turn OFF and ON the power switch.
2 Check the MFPB/1 connector for proper connection and correct as necessary.
3 Check the MFPB/2 connector for proper connection and correct as necessary.
4 Check for proper connection between MFPB/1 and MFPB/2 and correct as necessary.
5 Change MFPB/2.
6 Change MFPB/1.
Posted on Apr 29, 2015
Bizhub c20 show c503
Refer to the manual for a description of the error to rectify or repost your question describing the error.
Jun 22, 2015 | Office Equipment & Supplies
How do i rectify code 0208 in bizhub 350?
Hi
I have managed to find some information about your problems. The error 0208 I couldn't find, but C0208 refers to the paper lift tray 4. Neither could I find C0200, but all the C020x errors relate to Elevator failure (or paper lift tray). If you go here:
Error Codes Konica Minolta bizhub 350 Code C0208
then you can view the results for the C0208 error and by using the right hand drop down menu, any other error code. You can also download a Service Manual from this site.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 28, 2014 | Konica Minolta bizhub Office Equipment &...
Bizhub C450 has error code C-F023
CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job
Aug 23, 2014 | Konica Minolta bizhub C450P Laser Printer
I am facing p21 error in my bizhub c451 pls help me
p21 is stabilization failure. Try and clean the IDC sensors that sit below the transfer belt. also you can initialize and stabilize a few times in service mode as sometimes this can rectify a P21 issue. If all fails then it could be the actual ITB causing the issue
Apr 05, 2014 | Konica Minolta Bizhub C451...
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
I get the message "communication error occured" on my bizhub 250
this error usually occurs when the machine fails to make any connection with the computer or any other network, for example to send an email, through smtp, or while scanning using smb, if this message appears without these above mentioned reasons then its "communication board" problem.
Dec 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Bizhub 350 Error code c0211
It means Bypass Lifting Motion Failure, check pick-up solenoid and lift up sensor.
Reboot machine holding down utility button, then do trouble reset, if nessesary reboot again.
If this error occurs again, you have to call for service
Aug 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
75 people viewed this question
k24674
jasbo
jasbo
