Question about Samsung Washing Machines
Samsung washer will stops at drain and spin
Water pump was replaced because is was broke. After reassembly and checking carefully all connections, washer will stop at 11 minutes, and sit there doing nothing. got a ND a couple of times, then washer would resume. How much does the Interlock switch actually do..?
    Genius:
  • Samsung Master
  • 1,585 Answers
Tells the brains of mech if thiers water in tub so it knows wether to spin or not
Posted on Apr 29, 2015
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool Ultimate Care II washer Model#LSB6300LW0 that would not completely dry the clothes on the spin cycle. I'm not sure if the unit was spinning fast enough. I replaced the lid switch and...
It sounds like your Drain pump has either become clogged, or has burned out.
  1. First, disconnect the power to the machine.
  2. The drain pump is located at the bottom of the machine. You will have to remove the panel to access the drain pump, or you can access the drain pump from the bottom of the machine after you have removed the water from inside the machine.
  3. The drain pump has 2 hoses connected to it, and a wiring harness.
  4. Disconnect the hoses and wiring harness and remove the drain pump.
  5. Check the impeller inside the drain pump for coins, socks, etc. and clean it out if you can. Make sure it turns with ease, and isn't worn out, or rocking back in forth. If it is worn out, replace the drain pump.
  6. If after clearing the drain pump and reassembling, and the machine still fails to drain, replace the drain pump.
Jun 07, 2011 | Whirlpool Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up...
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Apr 07, 2011 | Kenmore Washing Machines
Water not leaving machine
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 17, 2010 | Samsung SW62ASP Top Load Washer
My washing machine will not spin and drain the water out
if it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 03, 2009 | GE WBSR3140DW Top Load Washer
My whirlpool duet washer will not spin all of the water out after the spin sycle. There is a flashing F2 on the screen.
F/02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Most likely cause is item 1.
  1. Check Screen Filter Assembly for foreign material lint, socks, coins, nails ect. To access the filter remove the lower front panel. The filter (white is located before the pump. Place a pan under the filter and remove it and clean then reassemble.
  2. Check the drain hose and make sure it is not plugged or kinked.
  3. Check the electrical connections at the pump and make sure the pump is running.
  4. If the above does not correct the problem, replace the pump.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Ge top load washer leaks from over flow during spin cycle
check your pump it may be partly plugged if it is try to clear or replace pump
Aug 06, 2009 | Washing Machines
Washer will not drain after washing and just stops and stays idle
Hi
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 05, 2009 | Whirlpool Ultimate Care II GSW9650LW Top...
Will not drain water after washing
it sounds like your lid switch ic either broken at the lid or it is non functional open the lid to manually see if it is broken you schould be able to see it visably on the lid if it is broke your machine will not go into spin and not drain
Nov 24, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Washer not spinning and draining water
I just had a similar problem. I broke down and had a repair man come out to take a look. He pulled off the front lower cover, took off the inlet hose on the water pump, and found my two year old daughters sock stuck in the turbine of the water pump. The motor runs both the drum and the pump, therfore it would not spin, and would not let the water drain.
Everything was fine until tonight. I'm having the same problem again. I pulled everything off just like my repair man did, but no sock. I think I might wind up pulling off the whole pump to check the otlet side.
Anyone else have any suggestions?
Dec 06, 2007 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
