Question about Garden
Looking for parts for trimmer head - Garden
    Top Expert:
  • 10,875 Answers
Your failure to provide fixya experts with the needed info,i,e,;make,model,year,exactly what the nature of the problem is,can get you all kinds of answers,we deal with 1,000's of questions without the needed info on a daily basis,if you expect a good reply then give the needed info!!!
Posted on Apr 29, 2015
Replacing head bearing
Here is what a blow out drawing looks like but since you didn't give me a model number...:
http://www.searspartsdirect.com/partsdirect/part-model/Ryobi-Parts/Grass-line-trimmer-Parts/Model-725R/0909/1503820
Jan 13, 2013 | Ryobi Garden
I have a L123 Husquravana brush cutter and I am looking for the lock nut that holds on the trimmer head. I am looking for the size to the lock bolt.
The trimmer head is not held on by a nut, the whole trimmer head is spun onto a 10mm male output shaft, to remove the trimmer head lock the geabox by inserting a 6mm pin through the top of the gearbox, there is a hole to take it, this will lock the drive disc, you can then turn the whole trimmer head clock wise ( left hand thread ) and remove the trimmer head. Parts are available for the trimmer head, it depends on which head you have, manual feed, or bump feed.
Nov 22, 2012 | Husqvarna 123/223L Brush Cutter Kit...
Where can we find help to install the head on a Troy Bilt weedeater trimmer TB20CS?
You will need to look at page 9 of the manual here. The string head installs part by part on the end of the driveshaft. If you are having trouble with the driveshaft turning while attempting to put the head on, post back. You shouldn't though if the end of the shaft's threads are in good shape. If you need to, spray some WD-40 on it prior to installation. Here is the manual.
http://dl.owneriq.net/c/c5ca28a7-c6a8-4dd0-8987-53c89193794e.pdf
Jun 08, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
NEED A REPLACEMENT BLADE FOR TRIMMER ER 240
panasonic WER961P replacement blades for beard trimmer panasonic er240 cutter replacement parts.
panasonic er240 replacement blades
May 12, 2011 | Panasonic ER 240 Beard Trimmer
I need to kno what the item number (so I can order) the line tensioner on my Poulan Pro Link line trimmer---PPB 335. It is a small plastic trimmer head cover. Do I have to order the whole trimmer head?
Your string head is part number 26 in the diagram. Home Depot's Garden department has a wide variety of parts including universal string heads and heads for Homelite, Ryobi, etc. and possibly one that will fit your machine. A lot of these trimmers have Poulan engine and trimmer head parts. See if you can get the complete assembly off the trimmer (if you haven't already) and take it with you to the HD and match it with a new one. The price of parts from an online supplier plus shipping will be almost as much as a complete replacement head. If you shop Ebay, there are literally hundreds and hundreds of weed trimmer parts on there and some good deals to boot.
http://www.mowerpartsweb.com/MANUALS/POULAN/PPB335.PDF
May 02, 2011 | Garden
The trimmer head stopped turning What could be wrong
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=225+L+%281994-06%29
almost sounds like the driving drum engagement end has rounded off or the end of drive shaft broke off at either end , or the gear head end is broken / damaged
have a look at the splines on the output shaft on the gear head , check the plate that engages those splines too
physicaly take off the tube / shaft assy from power head and check drum and clutch rotating , check drive shaft end (s)
if ok refit tube / shaft assy ( make sure engaged properly)
tighten mount bolts - remove gear head from end of shaft, start motor and run see if shaft turns ok with some rev s if so
problem is in the gear head
check out website good site
cheers paul hope it helps
Aug 01, 2010 | Husqvarna Garden
The trimmer head will not spin under power
The drive shaft is not set all the way into position. You will have to take the front casing off, as well as the lower part of the shaft, and work it into position that way. You may have to play with it a little bit.
Jim
May 30, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Mar 16, 2009 | Husqvarna Garden
The trimmer head on my Black and Decker cordless trimmer/edger seems to fall a few mm and the won't spin unless I push it back up the shaft. This is the second time I've had this happen in a unit after...
You probably have lost your return spring which will hold the head tight to the trimmer.Check to see if you have lost the spring. I would suggest looking on-line for a exploded view with parts list to see if you have any parts missing including the spring I mentioned first!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
