Question about Konica Minolta BizHub C252
Konica minolta c250 red color not printed - Konica Minolta BizHub C252
  • Konica Minolta Master
  • 6,161 Answers
Replace the Magenta image unit.
Posted on May 13, 2015
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 12 Answers
SOURCE: How do I get into service mode on a Konica Minolta
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
Posted on May 15, 2009
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
  • 55 Answers
SOURCE: Error code c0202. What is
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
Posted on Dec 23, 2010
Konica Minolta BizHub C252 - pale colors on the long side
Konica Minolta BizHub C252 Repair Questions,... - Fixya
www.fixya.com > Forum > Printers & Copiers > Konica Minolta
Konica Minolta BizHub C252 - pale colors on the long side · Konica Minolta. ... I have a Konica C250 machine which cannot print red color at all. I had changed ...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - On the right hand side of the drum (the part that has the large green handle) that easily slides out. There is a ..... I have konica minolta bizhub c252 colour printer. ... The K light came on a long time ago and is constant on now.
How to clean the drums/i units on the konica minolta number ...
? 0:28
https://www.youtube.com/watch?v=eD8HdNq0MlE
Nov 23, 2011 - Uploaded by Tennants Nottingham
How to clean the drums/i units on the konica minolta number plate printer ... Fix or repair color laser printer with fading, lightprint, or lines samsung clp 300 ... Imaging Unit Reset for Konica Minolta Bizhub C203 / C253 / C353
Dec 14, 2015 | Konica Minolta BizHub C252
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Konica C250 has a faded line on the prints. Prints colors well except for the Faded line.
The developer powder needs to be replace. for whatever color that's faded, wont be the drums.
Sep 06, 2014 | Konica Minolta bizhub C250 All-In-One...
My Minolta Bizhub c250 has lines of blue and red going though the images. It also seems to be printing Dark. Is this likely a drum issue or something to do with the fuser or transfer belt?
Open the front cover pull out the Cyan,Magenta,Yellow,Black image unit,clea used a vacum cleaner the copier inside.Open the right cover and remove 2 srews,remove the transfer belt unit and clean the transfer belt cleaning blade and the transfer roller unit located on the right cover.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
Bizhub c250 minolta all in one no color printing
What driver are you using? The only reason I have seen when these machines do not print in color is if you are using a PCL6 driver which is black and white only. Be sure you are using the PCL5c driver if you want to print in color.
Sep 24, 2010 | Konica Minolta bizhub C250 All-In-One...
Printer & scanning Driver for Konica color 8022
I believe that machine uses the same print controller as the Bizhub C350. You will have to verify this - it's an optional unit attached to the rear of the machine. It will be where your network wire plugs in. It "should" be a IC-401 model print controller. That's the driver you need from Konica.
Feb 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta BizHub C252 Logo
210 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
