DS3820PS1B1E1F power supply schematic
Needing schematics for all power supplies in this line. direction would be appreciated. send info to jimmobbs@wwps.ae
Coldcut
  • 1554 Answers
SOURCE: LG 42KK Power Supply Schematic Requested
you won't find any just ,
use a thermal probe or thermal gun as heat is likely the issue ,
if nothing else replace the main diode /rectifier and caps.
I find that if I replace the hottest items that usually the fix
if there is room for a small fan you will be doing them a great service and extend the life of the tv.
you may find some info on the power supply from one of these links they are generic enough
http://www.pacificdisplay.com/links.htm
Posted on Jun 10, 2008
Benimur
  • 6966 Answers
SOURCE: no output from power supply
I am assuming that you are very familiar with electronic circuitry and components, use of a DVM and a soldering iron. In the absence of a schematic diagram, and since you have perform initial voltage checks, perhaps you can wing it. Your "brick" will have to follow the basic design of an SMPS (switch mode power supply). Simply stated,an SMPS is an AC to DC to high freq AC then to lo V DC converter. Per your post, you have checked that there is DC (B+) from the AC mains, then what is needed is to check if there is oscillation to produce the high freq AC. Often design calls for an optical coupler, a small rectangular looking component with four pins, two at each end. This is nothing more than a LED and a Light Dependent transistor. Its function is to switch/trigger on the oscillation (and therefore start the SMPS producing the lo B+s).
Again, since there is no readily available schematic diagram, might I suggest that you post back the part numbers of the ICs and transistors. What we can do is pull out their spec/data sheets and/or application diagrams. Such would give us a general idea of the working voltages at what pins and what each component is supposed to do. Example, let us say your power supply uses a 817A/0635 opti coupler and/or an SG5841DZ controller IC, then we can search for them as initially described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
DickCanFixIt
  • 948 Answers
SOURCE: how can i determine if my power supply is dead?
You can see the pinouts for the power supply here.
Posted on Jan 20, 2009
DickCanFixIt
  • 948 Answers
SOURCE: I just need a schematic for the ATXpower250 power supply.
http://www.helpwithpcs.com/courses/power-supply-basics-inc-pinouts.htm#atx-psu-pinouts
SOURCE: 55HDS69 Power Supply problem
I have found that the power supply is usually good, it's the other boards that tell it to shut down within a second. There are input called Vsego and VSago that tell the power supply to stay on.
Posted on Mar 09, 2009
Want the schematic of the power supply for this model.
You'll need to know the model name and number of the power supply...if the info is not on a decal on the power supplies cover, open it up and check for any imprinted info- just make sure the power supply is unplugged when you open it up; then you can either:
  • Google the info;
  • check various online manual libraries
  • direct contact support with manufacturer
Mar 08, 2015 | Power Computers & Internet
KW-XR616, No audio, no protect or mute lines triggered, bit suss about the R2S25400 power supply IC but can't find a data sheet for it, any help appreciated. ;)
Why do you suspect power supply IC? Check voltages before you take the next step. Have you checked the condition of the front board. If pushed on the Volume control by force, it breaks. send me your email ID if you want schematic.
Sep 29, 2013 | JVC Car Audio & Video
Schematic atx diagram
I give up! Why would you need a schematic for a computer power supply? I've been in the computer business for over 30 years and have never needed a power supply schematic. Just curious!
Sep 18, 2013 | Antec BP350 350-Watt Power Supply
I need a schematic to replace the power board
No,schematic's the tv corporation don't release them.Replaced the power suppply board are easy.The power supply board,the board where A/C power line plug in,go in to.U just require a Philip screw driver take out about 6 Philip screws and connections.Do the reverse to install.
May 05, 2010 | Olevia LT42HVi 42 in. LCD Television
Jun 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
Computers & Internet Logo
503 people viewed this question
David Payne
David Payne
