Question about Delta & Single Handle Shower Faucet
How to fix delta shower single knob faucet
How to remove single knob shower faucet cartridge
    Problem Solver:
  • 8 Answers
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Posted on Apr 25, 2016
  • 659 Answers
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Posted on Apr 10, 2009
manhandy
  • 146 Answers
SOURCE: Delta single handle faucet. Hot or cold no in between.
well they should be same size but unless you getting more of one then other then sound like mixing valve is not mixing. do have 3/4 hook up to mixing valve? you only need 1/2" to valve.
Posted on Jun 26, 2009
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
meBNme
  • 334 Answers
SOURCE: repairing a delta single shower faucet. The handle
There is a nut that needs to be removed, allowing you to remove the ball assembly.
Look at the ring nut right below the #1 in this pic.
Your's should be similar to this one.
Posted on Oct 03, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Need to fix a leaking delta shower faucet and need
find the set screw on the handle loosen and remove handle, remove locking ring (a tool to do this comes with the replacement kit that you can buy from hardware store) remove the ball. You now have access to the washers and springs remove old washers and springs install new. reassemble in reverse. make sure not to overtighten locking ring.
Posted on Mar 31, 2010
How to fix bathroom shower faucet
shut off water to shower, remove knob by popping cover off and removing screw, remove valve cover by just pulling straight out. there will be a retaining clip that holds cartridge in you will need to remove, Pull out old cartridge and replace with new.
Feb 21, 2014 | Moen 3175 Legend One Handle Shower Faucet...
How do you remove the temperature knob and cover from a delta shower faucet, model 1824 (Monitor 18 series)?
http://www.deltafaucet.com/customersupport/documentation/1824-74.html?document=pd&documentIndex=0 The very center piece of the temperature setter pops off with a screw driver. Remove the screw underneath it and everything else to the handle comes off. Firmly grab decorative sleev behind handle and pull. Firmly grab round brass collar and turn counterclockwise. carefull pry cartridge from brass body.
May 22, 2010 | Delta & Single Handle Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
We have a very old Delta & Single Handle Shower Faucet. The screw in the handle is now stripped since it was so rusted. How can we get the plastic knob off???
you can try drilling a small pilot hole and then use an "easy out" (get'em at any hardware store). or take some large pliers and break the plastic handle and remove the whole cartridge. Go get a new cartridge and handle. Make sure main water valve is shut-off prior do doing so though.
Jan 17, 2010 | Delta & Single Handle Shower Faucet
I have a Delta one knob shower combo,and it been working fine then all of a sudden I go to take a shower and no water comes out of the faucet,I don't think it;s frozen pipes is there guts inside the faucet...
Hello. Delta uses a replaceable cartridge inside the faucet.Most commonly they will drip if they are going bad.There is very little you can do to repair the cartridge but replacement is affordable. Usually by removeing the handle and the next trim piece you'll be at the cartridge which should pull out but may be stubborn due to water deposits.Take the part with you when you go shopping,there are many different cartridges.
builderdale
Jan 10, 2010 | Delta & Single Handle Shower Faucet
Need to clean single knob shower cartridge from what i read - where do i shut off water first? hot water running to bathroom - sink gets it - in shower, cold water good, hot water trickles - read lots of...
To clean it, shut off the discharge valve at the water
heater. Then, you shut the valve off of the main water supply. After which, you can start cleaning the single
knob shower cartridge. After the cleaning job, you can
open the discharge valve of the water heater, then, the
valve of the main water supply.
Nov 11, 2009 | Moen & One Handle Tub & Shower Faucet
Single knob for shower and tub wont stop running
You may have debris caught in the cartridge. I'm not sure which faucet you have but if it utilizes a ball, there is a retaining ring that is either grey or white that you have to tighten. If not, I would recommend contacting American Standard. You might have a bad cartridge or missed replacing another part. Sometimes they have small round washers at the back of the housing that need to be replaced as well.
Apr 01, 2009 | American Standard T375248.002 Polished...
Delta & Single Handle Shower Faucet  Logo
448 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
