Question about Dryers
I plug my dryer in turned it on it flip breaker I flipped breaker back hasnt worked since
  • 62 Answers
Sounds like heating element has broken and shorted out.
you need to find it, test it with a volt ohm meter to make sure it's a dead short and replace it.
Posted on Apr 29, 2015
meBNme
  • 334 Answers
SOURCE: dryer flips breaker everytime
There is a short to ground somewhere.
Most likely where any wires go through the cabinet into the door or inside the door where a hinge or other moving part ir rubbing it.
Disconect power (unplug it) and inspect all wiring close to those areas for worn spots. If you have an OHM meter, you can ohm each wire to ground and see which one is shorted, then trace it back to the problem area.
Posted on Dec 30, 2008
kachbibi1
  • 979 Answers
SOURCE: dryer is a front loader
Check the wiring in the back to see if any wires are burned off. There is also a thermal fuse under the top that may be bad. You can check it and see if it is bad. I bet, however, the problem is in the wiring. The plug that goes into the wall may have a wire that is burned off as well.
Posted on Jan 21, 2009
SolutionGuy
  • 331 Answers
SOURCE: Dryer trips breaker after 5 minutes...BRAND NEW!!
Hi Shel,
Based on your description of the problem, I came up with a theory. Your new dryer is of higher wattage than your old one and is therefore pulling more amperage. I'd also make a bet that your dual breaker in the basement has the number "30" printed on it. Whether it does or not, your breaker should be replaced.
NOTE---> Ideally, you'd begin by removing the breakers (there are 2 of them) from the panel and take them with you to Lowe's, Home Depot or Ace Hardware and ask one of the sales associates for a 40 amp version. This way, you'd be sure to get the right ones. If you don't want to do that, then open up the breaker box and copy all the information off of the dryer breaker (also take not of how wide it is... 1/2", 3/4", etc...). Basically you'll need who made it (Square D, G.E., etc...) and how wide it is. Use this info to shop for a 40 amp version.
I don't need to tell you that working inside a breaker box can be EXTREMELY DANGEROUS if you are not careful. Here is a picture of the inside of the box, NOTICE THE LUGS AT THE TOP! THEY ARE ALWAYS "HOT" AND SHOULD NEVER BE TOUCHED!!!!!
Before you remove the panel to access the interior of the box, TURN OFF YOUR "MAIN BREAKER" (it's shown in the picture above).
Now that all of the safety stuff is covered, all you gotta do is pull the bad breaker out and install the new one! Piece of cake, really. Here's a video on how it's done.There ya go! If this has been helpful for you, please remember to rate this solution. Thanks for using FixYa!
SG
Posted on Apr 03, 2009
aasc
  • 1606 Answers
SOURCE: Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Posted on Aug 15, 2009
hunter19_46m
  • 7482 Answers
SOURCE: kenmore 400 electric dryer wont turn on.
Could be a bad motor, timer switch, belt off the pulley of the motor, or drum belt broken
Posted on Sep 25, 2009
The drum is turning but not heating up why?
It could be a bad heater, thermal fuse or if an electric dryer possibly one leg of your power is tripped and needs resetting at the circuit breaker on the house. Try flipping the ganged power breaker both off real hard and flipping them back on real hard and see if that restores the power to the dryer. If a gas dryer then the igniter or flame sensor could be bad.
Apr 28, 2015 | Dryers
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
My dryer is run on a 220 breaker and what is happening is the dryer will run for about 10 minutes and then the breaker will flip off then i flip the breaker back on and it will work for another 10 min
You must have something else on the circuit that is pulling additional power at the same time and tripping the circuit. Or you need a larger amp circuit.
May 14, 2012 | Dryers
I flipped the breaker in my fuse box to my dryer off and back on while the dryer was running. now the dryer wont come back on. what could be the problem and is it easy to fix?
if the unit was working fine before you flipped the breaker off then i would say you have a bad breaker... it is possible for only half the breaker to fail and you would still have a light and possible even tumble on dryer but no heat.... turn breaker off again and snap back on may require a few trys and it may require replacement of breaker...obviously the correct way to test would be with a volt meter (ac current) and test at your dryer where it connects are you getting 220- 247 volts on the 2 outside terminal connections... if not your breaker or plug has failed.... good luck to you
Jan 19, 2011 | Whirlpool WED5300S Electric Dryer
My dry quite working after my was work in electric box he was flipping power on and off
Your dryer is a 220 appliance and should be on a circuit all by itself. Are the items in your circuit box labeled (Lights? kitchen, etc.) One should be labeled "dryer". If you cannot locate one that is labeled for your dryer, Check out the position of the circuit breakers. If the dryer breaker is turned off it will be in the oppoite postion of the others.Caution: DO NOT do what he did and begin flipping breakers! If your dryer breaker is in the off position,is you should be able to flip it back on. Before you do this, have the dryer turned off.
If this does not work, unplug your dryer and leave it unplugged for 5 minutes or so, so that the dryers' operating system can reset itself. Then try turning it back on.
Dec 16, 2010 | Maytag Dryers
We flipped the breakers in our fuse box to do some wiring, when we flipped breakers back--our electric dryer will not start, but the light is on inside the dryer when I open the door
Hello- I would check the dryer outlet and confirm you are getting 220V. As well, flip the dryer breaker on an off again (it should be a double style breaker, 2 singles linked) sometimes they are sticky. Let me know if it still doesn't work. Best regards.
Sep 27, 2010 | Maytag Dryers
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Dryer flips breaker everytime
Dec 30, 2008 | Whirlpool WED5800S Electric Dryer
KitchenAid elec. dryer not heating
check and make sure your breaker isnt part way flipped .... dryer will run on 110v but wont heat unless it gets 220v ,,,, break may look to be on but not ,,, turn off breaker, wait 30 sec and flip back on hard / larryyb
Dec 05, 2008 | Dryers
Dryer dead
you have no power to dryer ,,,, turn the breaker completely off, count to 30 and flip back on ,,, should work, if not replace the breaker
Jul 03, 2008 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
51 people viewed this question
Top Dryers Experts
