A frozen screen on front load may tag washer
Touch screen makes a ding when you touch different cycle but will not open that cycle. Unplugged but did not help.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Inter lock could b faulty
Posted on Apr 29, 2015
My 2yr old washer has LCD screen which seems to be only responsive in one area of screen. beyond frustrating! Troubleshooting/repair cost experience appreciated!
http://www.ebay.co.uk/itm/New-Samsung-Dryer-Assy-PCB-Sub-LCD-Control-Board-DC92-01100A-for-WF457ARGSGR-/391328349713?hash=item5b1cfcbe11:g:h4EAAOSwp5JWVKyU
Oct 07, 2015 | Samsung WF457ARGS 27" Front-Load Washer...
Nothing happens when the 'Start Button' is pressed on Electrolux Front load washer
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
May 20, 2015 | Electrolux IQ-Touch Series EIFLS60LT 27"...
F21
This error occurs if the touch-pad/LED assembly is not able to
transmit/receive data to/from the central control unit (CCU).
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Mar 09, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
Code f21
1. Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch-pad/LED is responding. 2. Unplug washer or disconnect power. 3. Check wire harness connections to the touch-pad/LED assembly and Central Control Unit (CCU).
May 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 keeps on flashing???????????????????????????
This error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Apr 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Start a normal load then it stops and flashes f 21
3. after 10 minutes plug in and retry.
4. if this does not work you need service.
Apr 27, 2010 | Maytag EPIC MFW9700S Front Load Washer
What is code F22
This (F21 or FF22) error occurs if the touch-pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
See the full list of codes at:
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer goes right to drain when started
unit (CCU).
responding.
(CCU).
Feb 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
