Question about Garden
Error codes F923 & F423. Starts, won't move.
John Deere 450J dozier
    Top Expert:
  • 10,875 Answers
Call john deere,everything online requires an account and money,,, http://www.deere.com/en_US/products/equipment/crawler_dozers/450j_it4/450j_it4.page
Posted on Apr 29, 2015
2007 JD 450J 2500 hours: checked oil levels - Hydraulic and transmission. Engaged drive, normal PSI, crawled at very low jerky speed. Backed up some and then it stopped no PSI and no longer moves.
sometimes they have air pockets disengage the transmission
as to push. start put in gear and run this will help burp out air.
shut off and engage the transmission and try.
Dec 12, 2016 | John Deere Garden
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
John Deere stx38 won't move
i have the same problem, where is the differential release that you say to check after raising the drive wheels
Mar 14, 2012 | John Deere Garden
I have a John Deere RX 75 that worked perfectly fine. I just did maintenance by greasing some fittings and I sprayed WD-40 on some of the moving parts under the seat (throttle, levers, etc.). After I...
If it's a hydrostatic, most likey you pulled the manual over-ride (only way to move the tractor manually). By leaving the over-ride level in the disengaged position, the tractor will start & run, but not move forwards or backwards. Correct by closing the the lever to it's closed (operational) position.
Oct 18, 2011 | John Deere Garden
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
My 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Oct 10, 2009 | Garden
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
